Case Mod - In Progress "Stunning" CM 690 II Advanced ^^ : FINAL PICS
Discussion in 'Project Logs' started by Sassanou, 28 Nov 2013.
  1. Sassanou
    Sassanou What's a Dremel?
    3 Sep 2011
    Yes, there is a wordplay in the title ^^
    This Worklog will be very fast, but I want to share with you my work on a CM 690 II advanced that I make ;)
    So I hope you will like !
    Here I am at this time ;)
    Stay tuned for the rest !
  2. Falqoon
    Falqoon Minimodder
    13 May 2013
    Looking great!
  3. Parge
    16 Jul 2010
    Lovely lovely work! This is how the case should have been setup in the first place if you ask me! That motherboard is gorgeous!
  4. Sassanou
    3 Sep 2011
    Thanks guys !!!
    I think this week this mod will be finished ;)
  5. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Too bad you don't have time to show photos of the work involved. I like this mod. It just feels like it is done properly.
  6. Sassanou
    3 Sep 2011
    You're right mate, but you know, time is a real problem for me :(
    But anyway, here is a little modification : SSD support !
  7. Sassanou
    3 Sep 2011
  8. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    If it's done in the right way, I like flexible tubing better than acrylic tubing. And this is done the right way! Looks great :D
  9. Nexxo
    23 Oct 2001
    Clean loop.
  10. SiZZiGY
    SiZZiGY Nano Evolution in progress...
    11 Oct 2013
    C'est dommage que les inscriptions sur tes tuyaux soient visible ca casse un peu le délire "épuré" avec ces inscriptions totalement inutiles. Idem avec l'étiquette sur la pompe ainsi celles sur les prises arrière de la carte mère. Si tu as peur pour la garantie, tu les décolle proprement et tu les colle ensuite sur une feuille que tu garde soigneusement avec toutes tes garanties.
    Sinon c'est TOP :)
    english : on your pipe we can see disgracious inscriptions, maybe you can hide them? Not really work with your clean style. Same with the stickers at the pump and thoses on the motherboard plugs. If you are afraid about voiding warently, remove carefully the stickers and stick them at your invoice for the motherboard or pump to have them if any problem happend.
    otherwise it is really nice ;)
  11. Sassanou
    3 Sep 2011
    Thanks guys ! :)
    And SiZZiGY, it's for a customer, so he prefers to keep stickers ;)
    And it's over !
    here are final pics :)
  12. SiZZiGY
    11 Oct 2013
    Nice Sassa good job ;)
  13. Nikozii
    Nikozii What's a Dremel?
    29 Oct 2013
    So clean. I really like it. :)
    Only thing i woould change is that SLI- bridge. But that is so small thing.
  14. Sassanou
    3 Sep 2011
    He he, thanks guys :D
    For the SLI Bridge, you're right Nikozii ;)
  15. Shurika
    Shurika Minimodder
    9 Mar 2012
    applaud standing
  16. hero1
    hero1 Minimodder
    18 Oct 2013
    Awesome work Sassanou.
  17. Sassanou
    3 Sep 2011
    Thanks guys !
    Happy that you like this mod :)
  18. Hukkel
    20 Dec 2012
    Nice end result Sass!
  19. Sassanou
    3 Sep 2011
  20. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Very nice and tidy.
    I liked it ,since the motherboard is installed 90 degree rotated. The best solution for cooling. Aircooling or watercooling.
    But there is no pictures from the connectors on the top side of the case and the cover.
    Can you ad some pictures from top.
