Linux stupid fedora...
Discussion in 'Software' started by keef247, 10 Mar 2008.
  1. keef247
    keef247 Minimodder
    11 Aug 2006
    so its saying basically in short no matter what option i choose bar formatting the entire drive that there isn't enough space for / /boot etc etc... theres 30gb+ :|
    ... so yeah:|
    i'm thinking of either trying to gpart live cd and split the windows partition to a unpartitioned 20gb or just go with another distro...
    any suggestions on what to do or go with if not?
  2. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    What partitioning scheme are you using? How much space are you allocating for each partition?
    Andy
  3. keef247
    keef247 Minimodder
    11 Aug 2006
    basically.on ubuntu for example you can simply partition free space in your ntfs partition to make the required linux ones ie swap /home etc... and fedora has this option yet whenever i choose either of the ways of doing it ie delete previous linux partitions and create a new one/manually edit partition table etc it keeps telling me i haven't got enough free space:S when i have 30gb to partition off.makes no sense seeing as it has the option to use free space remaining on the primary partition...
  4. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    Gparted / Parted magic / Ubuntu live-cd (all got gparted on them) will be an easy way to fix your problem, with less risk than trying every option on fedora. I also recommand to defragment your windows hard drive before partitioning.
  5. keef247
    keef247 Minimodder
    11 Aug 2006
    yer thats what i was thinking... nah no need for a defrag i've only lol just formatted...
