Motors Stupid ****ing speedometer problem
Discussion in 'General' started by Shirty, 4 Jul 2013.
  1. benji2412
    benji2412 <insert message here>
    25 Apr 2009
    If he can't he clearly needs to attempt to top out the cars speed.*
    *Probably shouldn't do this.
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    disconnect battery , remembers he cant find radio code........
  3. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    Most clusters these days can do a gauge sweep in some form of button press routine. If that doesn't work then take it out and turn it back, could just be a dodgy motor.
    Also it's not illegal to change clusters. I routinely change customers clusters and pre 2004 you couldn't reprogram mileage. Just write it in your service book.
    Many cars use an instrument cluster as a main engine module and require immobiliser reprogramming. Ring your local dealer and explain what has happened, you never know they may instantly say its a simple speed sensor or less so simple cluster fault.
  4. Carrie
    Carrie Multimodder
    18 Nov 2010
    That's the technical term for it is it? ;)
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Actually, the technical term is "Impact Maintainance". :thumb:
  6. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Percussive Maintenance ftfw
  7. Shirty
    18 Apr 1982
    OK I got too drunk last night to attempt anything and will now be too hungover to attempt much today, but maybe on Saturday I'll have a go.
  8. BentAnat
    BentAnat Software Dev
    26 Jun 2008
    Points for honesty.
    I might use that at some point... :D
  9. jinq-sea
    15 Oct 2012
    I suggested that many posts ago ;)
    PS Honesty about being drunk made me laugh
  10. Shirty
    18 Apr 1982
    Best laid plans and all that....
    Oh my head :waah:
    Might have to pop to KFC shortly to help things along.
  11. Shirty
    18 Apr 1982
    Right, a quick revisit.
    Over the past five days I've noticed that every time I drive the car, the speedo needle returns to rest slightly lower than it did before. So on Friday it was resting at just over 20, yesterday it was down to 10, and now I'm down to just a couple of mph. As the problem is linear, that sort of means it has fixed itself.
    The MOT isn't due until next Spring, so I can guarantee it'll work flawlessly between now and the morning I drive it to the MOT garage, whereupon it'll go haywire again :rolleyes:
    YEHBABY likes this.
  12. mrbungle
    20 Sep 2004
    You haven't lived till you have taken a dash apart to its core components just to get the clock cluster out.
    Grab a few beers get a few friends round it is a riot.
    Then afterwards you get a stack of free extra screws that seemingly have nowhere to go. Its like magic.
  13. jinq-sea
    15 Oct 2012
    Total result matey!!
    I keep a box of these magical extra screws. They turn out to be useful for totally unrelated jobs!
  14. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Overcome by events. Just wait until it goes away or some other larger problem comes along to make it irrelevant! I'd have suggested getting used to subtracting 25 from everything.
  15. Xir
    Xir Modder
    26 Apr 2006
    "The mechanical engineers approach" :D
    Though you'll need to kick larger machines.
  16. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Sounds like some crap spacked out the speedo sensor, I know there just a Hal sensor but it doesn't take much to piss them off and go totally derp on you.
  17. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Incidentally, is adjusting speedos something that garages can/will do, and is it even legal to do? Mine has overstated my speed by 5-8mph for as long as I've had the vehicle, I'd much rather it was accurate - as I understand it, it's normal for them to overstate by a couple of mph, but this is really noticeably off.
  18. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I think they're allowed to overstate by up to 10% or something like that, but not understate, so I'm not sure what potential there would be to recalibrate a speedo whilst ensuring that it wasn't understating.
  19. Burnout21
    9 Sep 2005
    Have you got the original wheels? Changing in wheel diameter without adjusting the speedo does cause a headache that few people can correlate.
    My favourite aussie modders explain a fix to the problem rather well
