Here come the stupid questions 1.is a Z-chip block for the northbridge fan? 2.i've got a aqua waterheader with 10mm barbs the waterblock i want [danger den ]has 1/2 fittings,whats the best way to overcome this is it easier to fit 1/2 barbs to the waterheader or force the tubing on :eyebrow
Answers Hi, Answer to No.1 is Yes and you can see a review over at www.wc101.com For No.2 You could try using the following: find a 3/8" to 1/2" adapter and also a 1/2" piece of pipe see http://www.overclockersclub.com/dangerdencustomwatercoolingkitreview2.php to find out how this person did it. Hope this helps
