LOL Stupidest things you've done, or seen, when building PCs
Discussion in 'General' started by Guest-16, 10 Aug 2016.
  1. legoman
    legoman breaker of things
    28 Feb 2010
    OK not really an issue but amusing.
    Company decided to try a hardware swap cabinet. Imagine a remotely lockable unit size of a vending machine with 8 shelves each with a shiny new HP laptop in a dock and a KVM in the back we use to remote on and do stuff.
    Now, this thing also has a lovely glass front.
    Some numpty being told it needed moving took it for a trundle round to said place on a pallet trolley. Its very top heavy an needless to say fell over smashed the glass, broke the KVM an a few of the laptops.
    Best bit, it was only on a trial lease!
  2. gagaga
    gagaga Minimodder
    14 Dec 2008
    Transmeta Cheesecake.
  3. Guest-23315
    Guest-23315 Guest
    An entire 1/2" tube water cooling loop.. except I used 3/8" barbs on every block and wondered why I had just fried a brand new A8N-SLI Deluxe... :waah:
    THATS WHY WE LEAK TEST CHILDREN.
    Spilling a dirty pint from a game of ring of fire over a brand new Corsair K60 is pretty high too...
  4. David
    7 Apr 2009
    Leak-testing children would have prevented this, how exactly?
    Correct grammar and punctuation is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse. :p
  5. Elledan
    Elledan What's a Dremel?
    4 Feb 2009
    Improperly installing the HSF on an Athlon XP without thermal throttling? Check.
    Cutting self on those bits which clip into front-panel 5.25"/3.5" cutouts before learning to just whack them with a screwdriver? Check.
    Frying a PSU by playing with the voltage selector switch? Check.
    Having the FDD LED light up solid because of an improperly connected ribbon cable? Check.
    Wiping the contents of a HDD while partitioning without a backup? Check.
    Scaring myself because my first self-built system didn't turn on, but simply forgot to flip the PSU power switch? Check :)
  6. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I think I would have placed the comma in your first sentence after the "how" rather than after the "this".
  7. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    Ah, now that depends on where you want to place the emphasis in the sentence. Let's take the comma out of the equation and instead use an ellipsis to denote the pause (which, I realise, is not the correct way to use it); the sentence could be either:
    "Leak-testing children would have prevented this... how exactly?"
    or
    "Leak-testing children would have prevented this how... exactly?"
    The latter is probably more correct, but there's also the question of style: people often write on forums, blogs, comments, etc, in the same way that they would speak out loud. I'm probably splitting hairs at this point, but what good is the internet if a pedant can't use it to be pedantic? :p
  8. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
    Using Ghost to clone a HDD to a new drive and doing it the wrong way...
  9. Guest-23315
    Guest-23315 Guest
    Pampers on the PCB's. Duh.
  10. David
    7 Apr 2009
    What a noob - everyone knows Huggies are the best!
  11. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    I bought an Abit ITX motherboard.
    I still get angry at myself about it sometimes. Although, to be fair, that board is still technically working (it just sucks balls).
    For something more current: I still, to this day, forget to put the IO plate in the case before installing the motherboard. I forget at least half of the time. I must have done it dozens of times, my brain just refuses to remember about the IO plate.
  12. David
    7 Apr 2009
    I have done that before. I once failed to notice it until after I had spent hours on cable management and fitting a full watercooling loop.
    It was at least a month before I could work up the energy to strip it all down again.
  13. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Spent 2 hours putting a rig together for a friend at his flat, as he'd spent a small fortune on it and I'd never fitted an aio before i didn't want the slightest risk of chebbing anything. And it was the original h50 with the giant hsf pump unit. It booted up fine and he said he didn't realise it would take so long, so i told him it was because I went slow in case I broke something. "Oh don't worry about that l, I got the scansure insurance" :duh:
    Not removed a hsf protector. Plumbed the res to the out port when I modded an aio, the noise was unpleasant to say the least, but it worked well for years after connecting it the right way round. Shredded my fingers on a scythe ninja numerous times. Broke an m5g knocking some caps out with the aio hsf. Whilst sorting some issues with my brothers pc I saw some things I really wish I hadn't, he could have run his own site with his stash and it was even categorised in great detail :blush:
  14. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    I'm sure most have bricked a Dfi mobi at some point, I know I managed two in a row a number of years back. :)
  15. badders
    badders Neuken in de Keuken
    4 Dec 2007
    That moment when you realise you've used dd and accidentally transposed if= and of=.
  16. Gareth Halfacree
    4 Dec 2007
    I did this once, but with ntfsclone - which is slightly more forgivable as it doesn't require any suffixes and relies entirely upon the order in which the drives are listed in the command *and* does it backwards (target source) to the way I write dd commands (source target).
  17. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    Sleeping psu cables and flipped the 12v/5v molex around and fried 2 brand new 300gb SATA drives just when they first came out.... Doh that one scared me.
    Managed to RMA them without issue mind!!
  18. faugusztin
    11 Aug 2008
    Sleeping ? :D
  19. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Cables get tired too.
  20. Yadda
    Yadda Minimodder
    25 Jul 2003
    In the late 90's I once saw my boss at the time dribble into an open computer right in front of the owner, who had brought it in with a problem.
    He just slurped, wiped the motherboard with his handkerchief and carried rabbiting on, seemingly oblivious to the look of disbelief on the owners face. :hehe:
