Hardware Sub-£100 Gaming Sound Card Reviews
Discussion in 'Article Discussion' started by Sifter3000, 8 Apr 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Great timing with the article, I'm just about to upgrate from on-board sound. Thanks B-T!
    Edit:// Just found decent offer on Asus DX, getting me one of those.
  3. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Do share!
    Great article. I would've liked more coverage including music based cards, but nice to have something to read all the same. Thanks guys.
  4. Claave
    Claave You Rebel scum
    29 Nov 2008
    ^^ The clue was in the article name, tbh, but if there's more demand for music-based sound cards, we can look into that later.
  5. neonplanet40
    neonplanet40 What's a Dremel?
    3 Mar 2003
    Why no Auzentech cards? :s
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I'm curious to know why the article uses pictures for an alternative (and previously deleted) product rather than the product commented on. That is not the X-Fi Titanium. The X-Fi Titanium does not have a game port on the back of it and is also a PCi-E x1 componant.
    http://uk.store.creative.com/products/product.aspx?catid=1&pid=17927
    It would also be nice to have the review linked to a section about speakers and at what level these cards become applicable. If you are using sub £50 2.1/5.1 speakers, would you notice the difference between the cards or even todays standard HD Audio found on current Motherboards?
  7. bob
    bob What's a Dremel?
    15 Dec 2009
    Anybody know how the xonar ds would compare to a sound blaster audigy se on a 2.1 setup? I fancy an upgrade :)
  8. SchizoFrog
    5 May 2009
    Personally, as soundcards are about the only item to use PCi-E x1 sockets I would go for this, if you can't stretch for the more expensive cards:
    Creative Labs SB X-Fi Xtreme Audio PCI-Express x1 (New Version)
    http://www.scan.co.uk/Products/Creative-Labs-SB-X-Fi-Xtreme-Audio-PCI-Express-x1-(New-Version)
    But depending on the quality of your speakers, you may not notice any difference from your onboard audio.
  9. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    That's exactly what I was going to say: are sound cards really needed when most (if not all) motherboards come with onboard audio? I'd love to see a comparison of onboard vs add-on audio cards, perhaps using an oscilloscope as well how it actually sounds.
    More importantly, given the fact that an add-on soundcard is probably another £100 to a PC build, is it still a valid purchase (given the relative cheapness of most PC speakers) or would that £100 be better spent getting a better graphics card?
  10. impar
    impar Minimodder
    24 Nov 2006
    Greetings!
    Still remember when gaming sound cards used to give better FPS in games.
    Now... it just seems a waste.
  11. Xir
    Xir Modder
    26 Apr 2006
    If you've not reached a top-level graphics cards yet, I'd prefer to spend the money on the graphics, and go with onboard audio :D
  12. bitesreality
    bitesreality What's a Dremel?
    8 Apr 2010
    Damn, I got excited about that game port, got on old joystick which I could start to use again, was thinking of firing up some x-wing vs tie fighter.
    It would be good to know if its worth getting a sound card for the relatively cheap 5.1 speakers I have, not sure I would notice any difference from the onboard sound.
    Also does this sentence in the article seems wrong?
    If you're into films, you'll probably want surround sound support from your sound card – but your card still has to support the standard. If you're into films, you'll probably want surround sound support, which most sound cards (including the three we look at on these pages) support in either analogue or digital form.
  13. smc8788
    smc8788 Multimodder
    23 Apr 2009
    "Gaming" soundcards are a bit of a misnomer. I have a Xonar DX and it has dramatically improved the music quality over onboard sound, while I haven't really noticed the difference when it comes to gaming TBH. I would much rather spend an extra £50 on a sound card than say getting a 5850 over a GTX 275 (based on the prices when I built my system).
    Personally, I think that sub-£100 sound cards are the only ones worth buying unless you want gimmicky features. If you're going to spend over £100 you might as well buy a dedicated DAC.
  14. SlowMotionSuicide
    16 May 2009
    it's on www.verkkokauppa.com, though i doubt it'll be much of use to UK guys ;)
    I'll be pairing the card with Grado SR60i headphones, those should be decent enough heaphones to notice difference over the on-board audio.
  15. SchizoFrog
    5 May 2009
    What I think Bit-Tech are getting at is that when it comes to movies there are various standards used when it come to digital audio. THX, DTS, and Dolby Digital. If you want the best sound from your PC then you need to make sure that your soundcard (as well as your speakers) are certified to support these formats, or at least have an ability to emulate them.
  16. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    bought my X-FI xtrememusic to play BF2 - the sound positioning with headphones was brilliant and certainly helped me rack up the points... but that was a long time ago, and my X-fi is currently sat on a shelf... until I thought I could put it into my media pc; but that sends all it's audio via HDMI...
    Maybe I'll ebay it - can't be bothered to but the adapter to give me front panel audio
  17. SchizoFrog
    5 May 2009
    tonyd223 reminds me of a good point in regards to graphics cards. When I first bought my Palit 9600GT 'Sonic' GPU I was a little baffled by it having an optical in included in the back panel. Then I realised that I could run my optical out from the soundcard, loop it straight in to the back of the GPU and then out again via HDMI... While this may not be suitable for everyone, it was definately an unexpected bonus of my GPU purchase and something I'll be looking for in future GPU products.
  18. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    THX isn't an audio standard.
    Its an audio experience grade. You get THX certified speakers and stuff......it just means it qualifies to Lucasfilm (or something) standards for playback.
  19. Evildead666
    27 May 2004
    All the ATi 4x and 5x series have UVD which allows the playback of audio and video straight from the HDMI output of the card.
    Something I'll be looking into soon, since I plan to migrate to a uATX baord and case, but with two dual slot graphics cards.
    That won't leave any room for expansion, and its either the onbaord sound, or the full HDMI from the 5850, and a new HDMI capable amp....they're pretty cheap really, and do DTS-HD and TrueHD decoding for the most part....
  20. WildThing
    WildThing Minimodder
    26 Jul 2007
    Nice article. I liked the bit about the anatomy of the sound card, some useful info there. Cheers.
Tags: Add Tags
