Graphics Sub £200 graphics card replacement
Discussion in 'Hardware' started by Plugs, 28 May 2019.
  1. Plugs
    Plugs Minimodder
    5 Nov 2009
    Hi,
    After 6.66 years and ending on a red and black screen I think my Radeon 7870 has died this evening; therefore I'm after a replacement.
    I'm not a massive PC gamer and the 7870 was just about capable when I chucked something at it on 1080p resolution (even if it wasn't on high etc).
    I realise the market is very different compared to my last purchase, however I probably don't need the latest tech and I figured £200 was enough for me.
    I'm after bang for buck and longevity (that matches medium specs).
    Had a quick look and I see RX580 at ~£160. Not sure if it is worth stretching to the 1660 and RX590 just above the 200 mark. Is there much of a gain?
  2. RedFlames
    23 Apr 2009
    Plugs and Guest-44638 like this.
  3. Plugs
    Plugs Minimodder
    5 Nov 2009
    No. The devil loves rounding coincidences.
    Interesting to see a couple of these are in budget
    Is there a firm date on that release? Not sure I can wait months or more than a few weeks.
    Feeding in terms of?
    I like a variety of games, from simple indie to strategy to fps, though I'm also a PS4 owner so I'm used to low-medium graphics and can use that for super intensive games that require better optimisation.
  4. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    When he says feeding he means what processor, ram etc.
  5. Plugs
    Plugs Minimodder
    5 Nov 2009
    Mid range 6.66 year old things
    i5 3570k
    16gb ram
    Ssd
  6. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    There isn't a lot of difference between a 580 and a 590, but there is a huge difference between a 7870 and a 580 - Heck, even a 4GB 570, which can be had for under £120 (with free games), would be a massive jump in 1080p performance.
    Then save the extra for when you're ready for a full system re-build?
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    One potential gotcha is power: your 7870 draws around 170W. The GTX 1660 sips a mere 120W so will be fine as a drop-in. The RX 590 however chugs down ~240W, so depending on what PSU you have you may need to add the cost of a new one to the cost of the GPU to get your actual outlay for an upgrade.
    Plugs likes this.
  8. Plugs
    Plugs Minimodder
    5 Nov 2009
    Yeah maybe I can go more basic than I think. Though that specific model doesn't have the right ports required
    A good point I hadn't considered, however I think I have enough headroom for another 70w. Will check though
