Cooling Submersion Cooling?
Discussion in 'Hardware' started by geek1017, 11 Sep 2002.
  1. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
  2. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    i though about doing it, i ahve a thread in it further down the list someware, ti can be done with a cheaper & less damaging chemical naimed in the thread but im a little but oo angry with comments a usr made in another forums about me to seach but it is easy to find, in the end i could not afford to pull it off (htat & i was afraid my precious hardware would go pop)
  3. geek1017
    6 Aug 2002
    Can this fluid just be used as an alternative to water in a standard watercooling setup?
    The fluid still needs to be supercooled (by dry ice according to the article).
    So could you just use a chiller like a dehumidifier and substitute this stuff for water?
    Is it worth it?
    Might just be fun to try though.
  4. TiTch
    TiTch h2o cooled
    19 Oct 2001
    submused mobos are not new. the main reason is to combat the condensation created by going below ambiant. oils etc have been used etc. However they normally operate in conjuction with an evaporative cooler. This system is interesting because it cools the whole system. I have never heard of them being used for long periods successfully like with a promethias that goes down to -25c and the new vappochill, which will go to -30c.:dude:
