Modding Sui's Psone LCD Mod
Discussion in 'Modding' started by sui_winbolo, 8 Jul 2006.
  1. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
  2. Cardan
    Cardan New Member
    21 Jun 2005
    wow so nice and clean!
    very good
  3. DAE_JA_VOO
    DAE_JA_VOO New Member
    11 Nov 2005
    Very very nice :D
  4. Lucanus
    Lucanus New Member
    13 May 2006
    Good job.
  5. sui_winbolo
    25 Sep 2004
    Thanks for the comments guys. :D
  6. Noni
    Noni New Member
    8 Dec 2005
    Looks sexy!
  7. GuardianStorm
    GuardianStorm Active Member
    26 Apr 2005
    nice :) i would frost the rear of the surrounding acrylic holding the psone in place, but appart from that :thumb:
  8. olly_lewis
    olly_lewis New Member
    19 May 2006
    Great mod and the case, the cooler master is a great case and the PS screen finsihes it off great and the translucent acrylic is slightly see through and seeing the jubbings is a great touch to the mod as well as the metal surrounds for the case, they make it look quite industrial....
    Nice job
  9. ARTbyTROY
    ARTbyTROY Mod it Til it Bleeds!
    27 Jun 2002
    Nice mod sui, were it mine I would stealth the ROM drive and throw a Matrix Orbital MX display into the 5.25 bay with the 3.5 cutout (like this)... but that's just me, Mod it Til it Bleeds!
  10. sui_winbolo
    25 Sep 2004
    Thanks for the comments guys, I use to have a piece that covered the drive also. But it didn't look that good, so I cut it off. Haha, that would be nice, but I don't have $80 to spend on one of those. (or whatever the orbital LCD costs)
    I actually got my idea from CaseModGod and bit-tech. Thanks for the guides guys!
  11. The_Gnu
    The_Gnu 8-bit addict
    12 Sep 2005
    very nice... I also like that frosted plexi and the slight seethrough effect.
    how about removing the front of the dvd-drive and stealthing it with another piece of frosted plexi? :)
    /GNU
  12. sui_winbolo
    25 Sep 2004
    Click the link on my first post, I tried it, didn't look so good. :sigh:
  13. Firehed
    15 Feb 2004
    Don't worry, the PS1 screens are a load more functional than any character LCD out there. Especially when combined with Samurize. You can get parallel (HD44780) character LCDs pretty cheap though, far less than the USB or even serial ones, and typically can use the same controller software.
    I too think it looks great, but I'd have frosted both sides of the plexi to make it a bit more opaque.
  14. sui_winbolo
    25 Sep 2004
    Actually I did frost both sides of it, I only used 1000 grit sandpaper though. And didn't spend alot of time on it.
  15. H0w1ingM@dMurd0ck
    H0w1ingM@dMurd0ck New Member
    4 Jun 2006
    That looks beautiful. Very tidy.
    How did you stick it on? Did you glue it?
  16. The_Gnu
    12 Sep 2005
    Okay I see..but I was more thinking of removing all of the grey plastic at the front of the drive and rebuilding it in frosted plexi to create a similar see through effect as above. Just a thought , not sure of how it would look.
    /GNU
  17. sui_winbolo
    25 Sep 2004
    I used some very sticky double sided tape. :thumb:
    Gnu, I don't think that'll look very good, but who knows. It could turn out very nice.
  18. zachjowi
    zachjowi New Member
    15 Jan 2005
    I have wanted to do something just like that with one of my screens but I can't get the wiring correct:(
  19. sui_winbolo
    25 Sep 2004
    If you can't get the VGA method you could always do what I did, I used RCA/svideo.
  20. H0w1ingM@dMurd0ck
    4 Jun 2006
    Its a lot easier just to use the TV out and connect it up to the video in on the screen. I've had MSN on mine running about 400x300ish using powerstrip and its 'not so bad'.
    It depends what you want to display on it. If its text then you really need 640x480 resolution and a VGA connection unless you like squinting but for stuff like winamp graphics, video or temp displays then a TV out connection is fine and a hell of a lot easier.
