The fan on my fenrir has started ticking. What would be a suitable replacement? If it's an expensive one would I be better just to upgrade my cooler altogether? Cheers
any 120mm fan should suffice surely? I have a titan fenrir at home, you are welcome to the fan if I can find it - it even says titan on it and everything if remember correctly
If you don't mind the looks throw a Noctua NF-F12 on it or 2 if it will allow for 2 and you have room in your case.
Hi Margon I was mainly asking for advice really as I wanted to keep the performance and noise levels the same. How much would you want for the fan, it might be ideal to replace like with like.
I have found it - it's one with a silver middle and black round the outside? is that the same as yours? You can have it man just pm me your address and I'll get it posted.
That sounds like the one from memory. That's very nice of you mate, I'll PM you now. It started to rattle even more today after I tinkered in my pc so my almost silent pc is now rather annoying.
