Case Mod - In Progress Summer Project -=[water cooling a Lian-Li PC-V300]=- April 12
Discussion in 'Project Logs' started by Tec_, 30 May 2008.
  1. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    from the grave
    its been a wile guys, but im starting to gear up to buy parts for this project. There is a east coast lan / gaming convention im planning on taking this to in March.
    this is what im looking at so far.
    Motherboard.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813136055
    and Processors
    (1) Intel Core 2 Duo E8400 Wolfdale 3.0GHz
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
    OR
    (2)Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
    thing is this will be the first time i work with Intel or ATI ive always gone AMD in the past so any insight / input / wisdom you could contribute would be vary cool.
    oh the lan event is Digital Overload incase you wanted to know.
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    Q6600... you can O/C it to 4GHz/core on a decent liquid cooled rig
  3. The boy 4rm oz
    10 Apr 2008
    A quad core is also future proof as programs are still being written to utilize all 4 cores.
  4. Tec_
    26 Feb 2008
    i would agree so far im leaning towards the quad. any one have any wisdom to share about working with Intel CPU's or about using ATI i have never used them before.
    and im hoping to order some parts by next thursday/friday. But I wont be back from my business trip to be able to work on it till around the 28th so im going to start ordering parts so that when I do get home everything should be there.
  5. andybones
    andybones What's a Dremel?
    1 Sep 2008
    Qx6600 is the best clocker.keep up the good work.
  6. SergeantMajorLogan
    SergeantMajorLogan General
    31 Aug 2008
    Not bad lol i like the powder coated case. nice colour. I would'nt mind perleasent paint thogh on mine. good work
  7. nannycakeole
    nannycakeole What's a Dremel?
    17 Sep 2008
    That is wrong mate.
    4ghz q6600s are rare with out massive volts. Quads just dont like high fsb.
  8. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    thats semi true, if its a G0 stepping like mine then 4GHz on water isn't unlikely, its just easier to take a E8xxx series and get 4GHz thats all.
    You dont really need a Quad over 3.2GHz anyway as they still munch though anything! Well FEA stress analysis and rendering kills it a little but gamers dont do that kinda work tbh as its nothing to do with gaming!
  9. Phoenixdancer
    Phoenixdancer What's a Dremel?
    17 Sep 2008
    Nice a small case :D gota love them!
  10. bigsharn
    9 May 2008
    Sorry, forgot the GO bit needs mentioning :p
  11. Bradley8988
    Bradley8988 What's a Dremel?
    16 Jun 2008
    I would go dual but meh.
  12. Tec_
    26 Feb 2008
    Any particular reason why?
    And thanks for all they help so far. This will be my first time working with a intel chip and I like knowing what im getting in to.
  13. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    I've been using a Q6600 all summer, and I love the thing, crunches through anything I can throw at it
  14. Tec_
    26 Feb 2008
    well guys ive hit some walls.
    First Wall
    i went to buy my parts last week and my card was declined.:wallbash: it had expired and i was out of town so i couldn't activate my new one. i got home from my trip and went to activate it and was told i have to call my bank to do it but i have to call during business hours. so ill fix that on Monday and buy my parts.
    Second Wall
    i picked up a Swifech Radiator and a Danger Den Fillport
    (not the actual motherboard im going to use)
    and on to the wall my case is to small/radiator is to big by centimeters for the setup i had in mind.
    i originally wanted to put the radiator in the front of the case but it looks like thats not going to work out.
    i have the option to mount the radiator in the side of the case
    but to do that i would need to perform surgery cut half of the HDD rack out and a little more than half of the drive bays (witch is going to need some work for the video card to fit) and to then fabricate a new side panel out of plexi. wouldn't be that bad and i could mount my pump on the floor of my case.
    or i could return my radiator try and find a smaller one that would fit and keep my side panel (cut a design in it) and mount my pump in the part of the drive bay i wouldn't have to cut out.
    im in a toss up as to what to do.
    oh and i got a free APC (forgive the rats nest)
  15. The boy 4rm oz
    10 Apr 2008
    For how you wanted to mount the rad I would have got 2 120mm instead, would have fit for sure. Probably could have got thicker radiators like the Black Ice Xtreme for better cooling with quieter fans.
  16. Tec_
    26 Feb 2008
    i still might yet. like i said i can take the 2x120 back. im just not sure if i want to.
  17. Tec_
    26 Feb 2008
    well my decision was made to day i figured out how im going to do it.
    i decided to cut out one of the 2 HDD racks and to cut out the left side of the 5.3 bays (the case has the option to use both sides)
    im going to make a new side panel out of acrylic that is on its way.
    the side my disk drive will be on. (acrylic will be used for the window)
    the radiator side mocked up with a scrap piece of acrylic
    hear you can see ware i cut the HDD rack and the drive bays.
    Note
    the motherboard is just for mock up purposes.
  18. The boy 4rm oz
    10 Apr 2008
    Fits great there, run with it.
  19. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    The idea is nice, but you have a lot of filing to do! The edges of the aluminium and the plexi looks terrible. If you sort that out, the case will look hell of a lot better ;)
  20. Tec_
    26 Feb 2008
    no i know that. i haven't had time to file it down yet, and as for the acrylic its just a scrap that i was using to see if that is ware i wanted to put the rad. i just received my shipping conformation on my acrylic, im thinking i might yet paint the HDD rack and the drive bays.
