Modding Sun damaged beige plastic help needed
Discussion in 'Modding' started by jhanlon303, 15 Mar 2011.
  1. jhanlon303
    7 Sep 2006
    I want to restore one of my earliest beige plastic sun damaged case mods. Any suggestions on how to do this? Polish of some sort? Repaint in beige paint(they even make that?) I can show pics if needed.
    john
  2. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Beige vinyl dye?
  3. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    VInyl Wrap could be funky .. I don't think you can polish out sun damaged plastics as its more a chemical change in the material rather than a "finish" blemish like wood or painted surfaces
    Has it gone milky looking?
  4. Attila
    Attila still thinking....
    22 Feb 2008
    A couple of rattle cans and a couple of hours John. ;)
  5. MattMc
    MattMc What's a Dremel?
    5 Oct 2003
  6. Guest-23315
    Guest-23315 Guest
    Give it a sand to get down to some newer plastic?
  7. Guest-2867
    Guest-2867 Guest
    +Rep
    Retr0brite will work magic on your yellow stained plastics, I used it on my old Amiga stuff when Merlin on amibay was dreaming this stuff up/testing, the results are amazing
