Modding Sunbeam Rheobus
Discussion in 'Modding' started by keiron99, 25 Sep 2003.
  1. keiron99
    keiron99 What's a Dremel?
    14 Sep 2003
    I'm interested in buying this but can someone please answer a few simple yes / no questions?
    Am I right in thinking it includes a template so that I could remove its guts and attach it to a face plate on my Lian Li case?
    Is it possible to actually remove the LEDs?
    Does it emit a buzz?
    When turned right sown, does it switch the fans off?
  2. Guest-16
    Guest-16 Guest
    My model is 6 months old now, so i dunno if they changed the revision at all but the LEDs are simply pull-out and it emits no buzz i can hear.
  3. keiron99
    14 Sep 2003
    Can anyone tell me if the versionfromMaplins (£30), is the same as the one from Kustom PC (£27) and Ebuyer (£12ish) - I'm more thana little confused!
  4. Guest-16
    Guest-16 Guest
    Ebuyer one is OEM and doesnt have all the crap over the front bezel and it has screw in connectors not 3 pin which imo are more useful.
