Hello a while back I bought the Sunbeam Sound Module for my lights. I never used it because to turn it off I would have to open the case and turn it off. http://store1.yimg.com/I/xoxide_1811_32530705 Is there a way to hook it up to a rocker/toggle switch? like a normal cathode light? Thanks.
Never mind I had my dad look at it . And its not possible. Because the rockerswitch turns off the light and I just need the power part it on and the power is allways on. He said i can do it but I have to rewire the rockerswitch wire to the power cable.
that actually what i thought you ment in the first place i always put the switch before the inverter box check this link if ya wanna know what sorta problem colda happend wired the other way
LOL thanks for that. I have my Uvlight wired to a switch and once I hooked it up to my harddrive! So it would reboot everytime I hit the switch. DOH....
