Modding Super LAN Boy front door cover
Discussion in 'Modding' started by zachjowi, 17 Aug 2005.
  1. zachjowi
    zachjowi What's a Dremel?
    15 Jan 2005
    I have an Antec Super LAN boy case and I want to remove the front door with out breaking it or the hinge pins. How shoud I do this? The reason I wan to take it of is so I can put an LCD behind the back of the door.
  2. csTYCOON
    csTYCOON What's a Dremel?
    10 Aug 2005
    I just pulled mine really hard haha...worked :p
  3. zachjowi
    15 Jan 2005
    did you break it?
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Take the whole front panel off, it's only a few screws. If you want you can just take the ones out of the hinge side out, and it'll let you bend the frame so that the dor just pops out. Don't be too afraid to force it, it's quite strong.
  5. zachjowi
    15 Jan 2005
    If I don't want to cut up my front door how could I make a replica using Bondo?
  6. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    not out of bondo..., its a filler, its not really meant to be somelike that..., only advice i can give, is you cannot plan enough ur first go at it, measure it 3+ times, pracitce cuts, think of how lcd will be mounted etc, if u do it right the first time, you wont have to worry about it...
  7. zachjowi
    15 Jan 2005
    If not bondo is there any other type of material I can use like when people make custom fitting sub boxes?
  8. Graffix
    Graffix What's a Dremel?
    5 Jul 2005
    they use mdf and then fill it out with fiberglass :D
  9. zerokool04
    zerokool04 What's a Dremel?
    5 Oct 2004
    I broke the door off my Antec plusview, So I emailed asking them nicely where I could buy a replacement.
    The replied asking for a invoice for the purchase of my case, So I provided an ebuyer print screen, and within a week they had sent me a whole new front, and I had only asked for the door. Im not complaining though its great for spares, but I mean you dont get any better customer service than that.
  10. LoneArchon
    LoneArchon What's a Dremel?
    15 Jun 2004
    i just popped my off with a little force it didn't break. I have done this a few time and it is still one piece.
