Case Mod - In Progress Super Monsta
Discussion in 'Project Logs' started by SuperMiguel, 31 Oct 2014.
  1. SuperMiguel
    SuperMiguel What's a Dremel?
    14 Oct 2014
    hehe i will plug it soon, and check how many watts im pulling
  2. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Let us know what country you're in so we can look for you when the blackout makes the news. :D This is insanity, but a good insanity!
    andrew8200m likes this.
  3. jodah175
    jodah175 Wannabe Modder
    26 Oct 2006
    While I applaud over the top builds, this goes well beyond that. You went from Ludicrous speed to plaid! XD I'm sure your electric company will absolutely love you!
    ninja edit: Who on this planet still uses 56k?! o.0
  4. SuperMiguel
    14 Oct 2014
    Im in USA my electric bill will prob go up $5 if that per month, not that much honestly,
  5. SuperMiguel
    14 Oct 2014
    So the Monsta is alive!!!!!!!!!!!!!
    http://www.youtube.com/watch?v=BJmokKfWiUk
    Sorry for the ****ty video
    Also missing few fittings here and there... Will buy them tonight... Stupid math always wrong :p
    On the previous videos all rads are installed, all tubing done... Running all rads with all 4 pumps, with out any waterblock (ie CPU, GPU)
    Results without any blocks/heat sources
    Flow : ~500L/h
    Room Temperature: 21.85 C
    Loop Temperature 22.7 C without fans
    Loop Temperature 21.88 C with fans
    Running all 80 fans at (6V ~700RPM + 4 Pumps) + Aquaro 6 = 140W using kill-a-watt
    On the video the system was loud because the amount of bubbles it had inside, but now that it has less it is near silent... every few minutes i would hear bubble noise, but not ofter... The only thing i can hear if i get very close to the system is the impeller inside my flow meter... But im sure once i add my blocks it will be gone since flow rate will decrease.
  6. jodah175
    26 Oct 2006
    where in the us so i can move there and get cheap rates? XD Electricity isn't cheap in CT, lolz
    lookin good in the vid though. How long did it take to bleed completely?.
  7. SuperMiguel
    14 Oct 2014
    about 1h, but i still have air inside, havent found a true way to bleed it
  8. SuperMiguel
    14 Oct 2014
    Getting there:
  9. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    :thumb: Dude, that is mental.
  10. SuperMiguel
    14 Oct 2014
  11. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    You've put in a lot of nice 'n expensive hardware. That's always nice!
    But, are you going to do any actual modding?
