Windows super noob question about original CS
Discussion in 'Gaming' started by sotu1, 5 Nov 2008.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    hey...so this is an embarrassing question....where can I download a standalone copy of counter strike? you know, the old one. the really old one. some friends and I are planning on having a little lan party but I don't actually have CS. any ideas where I can get a decent copy that requires nothing else?
    cheers!
  2. Krikkit
    21 Jan 2003
    Steam. :)
  3. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    do you have to use steam? is there no other way around it?
  4. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    :cooldude:
  5. Krikkit
    21 Jan 2003
    Well, you could try buying a CD copy, but you'd have to patch it up, and iirc you won't be able to access all the servers hosted with the current version on Steam, only ones hosted with the Steam-free version.
    Tbh, just bite the bullet. $10+taxes gives you a game which is easily accessible with a massive wad of servers. :)
  6. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    Do you mean super old school, as in v1.0 or v1.5, or are you okay with v1.6? If you want 1.6, Steam is the way to go. If not, you should be able to pick up an older version for less than US$5 on Amazon. Google hints at free mod version downloads if you already have Half-Life (search for "Counter Strike 1.5").
    If you get 1.5, you won't be able to play online (i.e., over the internet), but LAN should work without any problems.
    It may be worth checking out Steamless CS.
  7. heir flick
    heir flick Minimodder
    2 Feb 2007
  8. heir flick
    2 Feb 2007
    im 99.9% sure ive got it here somewhere
  9. PQuiff
    PQuiff What's a Dremel?
    7 Sep 2001
    i got it with my Orange box and original DOD as well.
  10. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Surely someone must mirror pre 1.6 versions of CS? Im sure I have them on CD somewhere...
  11. identikit
    identikit Minimodder
    5 Jun 2004
    I've got CS 1.1, it's 85megs. I'll upload it later if anybody wants it.
    (Also got PODbot which is nice for padding out a LAN server with (pretty useless) bots)
  12. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    You can play any version of CS, just google for links to dl the patches not sure about dling a version of the game but you just need someone to host a lan game and you then all connect to that PC, if you all have the same version it should work.
  13. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    cheers guys! it's purely for LAN purposes, nothing more. and tbh, any version is good, so long as it works ok-ish! indetikit, could you upload CS 1.6? I would much appreciate it!
  14. identikit
    5 Jun 2004
  15. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    brilliant, thanks very much for the link!
