Blogs Super-wide monitors - the next big thing?
Discussion in 'Article Discussion' started by Meanmotion, 11 Jul 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    sure, i'd take a super wide monitor. so long as it keeps the same pixel density as my current. i can't see how many pixels were on the one you tested... pretty important
  3. Blackshark
    Blackshark What's a Dremel?
    13 Apr 2004
    I remember the feeling I got when I unboxed by Dell 30 inch all those years ago when it first came out. Then running a 19 inch next to it so i could WoW on the Dell and team speak etc.. on the 19 inch.
    This screen ratio looks really nice, great for coding on.
  4. DbD
    DbD Minimodder
    13 Dec 2007
    I'd buy one so long as it was 120hz - preferably with 3D vision 2 light boost.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Staff
    5 Dec 2011
    1080p@21:9 ratio
    =((1080/9)*21)*1080
    2721600 pixels
    If you want i could waz out some pythagoras to get the area and ppi?
  6. sakzzz
    sakzzz Minimodder
    13 May 2009
    So what is the aspect ratio and resolution?
  7. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I assume it's 2520 x 1080, i.e. 21:9 aspect ratio, but it might have been useful to state this in the article :D
  8. greigaitken
    26 Aug 2009
    1080/9*21 = 2520
    so this is 2520 x 1080?
    that's less pixels in both directions, that is not improvement.
    LG does not get my money.
  9. David
    7 Apr 2009
    I can achieve that effect on my 2560x1600 monitor :D
  10. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    The resolution is 2,560 x 1080 - I've just added this to the article too.
  11. The_Crapman
    5 Dec 2011
    no one said this was 'an improvement', just a different way of viewing things.
  12. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    So it's a 64:27 aspect ratio, not 21:9 :)
  13. wyx087
    15 Aug 2007
    Ultra wide 29 inches are a marketing device. You get less screen than 27 inches and a quarter less than 30 inches. It's not a lot bigger than a 24 16:10.
    The wider we go, the less actual screen panel we get, it's basic trigonometry:
    3:4:5 triangle => 5 units diagonally on the product page => 12 unit^2 for the rectangle viewing area
    1:5:5.1 triangle => 5.1 unit diagonally on the product page => 5 unit^2 for the rectangle viewing area
    In case of monitor sizes:
    30inch 16:10 monitor has viewing area of 404.5 inches square.
    29inch 21:9 monitor has viewing area of 304.5 inches square.
    27inch 16:9 monitor has viewing area of 311.5 inches square.
    24inch 16:10 monitor has viewing area of 258.8 inches square.
    So say no to those marketing monkeys and save your money for a 30 inches.
  14. faugusztin
    11 Aug 2008
    Not going to happen. 120Hz = TN = 24" 1920x1080 at best. Time to choose - either a superior IPS display, or 3D Vision/120Hz. I take superior IPS display with superior resolution (2560x1440, 2560x1600, 4k monitors) over 3D Vision/120Hz any day.
  15. technogiant
    technogiant What's a Dremel?
    2 May 2009
    Naah, just give me Occulus Rift already
  16. Meanmotion
    16 Nov 2003
    You're technically right, but the very same argument could be said for 'widescreen' monitors in general. Why not have 3:2, 4:3 or 1:1? There's a 'feel' associated with using a monitor that counts for something. Having used a 30in monitor for many years I can vouch for the fact that 2560 is a great resolution for working side-by-side, while the extra height is of limited benefit day to day. Would I actually want to drop all the way to 1080? Well, maybe not but certainly 1200 is enough.
  17. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    Yeah baby!
    That's my requirement too. I love the super-wide but I like 3d vision 2 and also I can't go back to a 60hz desktop. 120hz is fast and flicker free.
  18. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    There's a very good reason why aspect ratios aren't closer to 1:1, and that's because our field of vision is naturally wider than it is tall. 4:3 isn't too bad, but 16:10 or 16:9 is much more "natural" imo. I've not used a 21:9 (64:27 :D) screen so can't comment on how good a fit it is for our normal fov.
  19. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    I miss my 5:4. My 16:10 is okay, as it goes, but I'd prefer more vertical resolution - without going to the extent of rotating it and having a 10:16 monitor instead...
  20. Xir
    Xir Modder
    26 Apr 2006
    What I miss in the widesreen monitors is a gain in height.
    My 24" 1920x1080 is the same (screen) height than the old 19" 4:3 monitor.
    The gain in width alone doesn't do it for me.
    Suppose I'll have to save for a 27"-30"
Tags: Add Tags
