Displays Surround Gaming: 8560*1440 vs 7680*1440
Discussion in 'Hardware' started by pcb, 29 Oct 2014.
  1. pcb
    pcb What's a Dremel?
    2 Feb 2014
    Hi guys,
    i recently upgraded my Gpu to a gtx 980 with stock cooler but plan to sli it in 2-way or even 3-way. Next step on my list will be a monitor upgrade from my old crappy acer 22" 1080p paired with an even older NEC 15" to either 3 Rog swift or one of these tasty LG 34UM95 with a 27" 1440p on each side.
    I use the PC mainly for gaming (Crysis2&3, Call of Duty MW3, Ghosts & Advanced Warfare, and some F2p like LoL & WoT) but also for work (Excel, Word, vba & C# Spotify :D ).
    1. What do you guys recommend, the Rog swift or the LG?
    2. Is it even possible to game on the 21:9 with the 16:9 on each side? How about Nvidia Surround? I heard one can use only the same sized displays for surround.
    3. Which 27" Display would u recommend to pair with the LG? The Rog swift seems a little bit overkill next to the 60Hz LG but i didn't find any other Displays with smaller bezels.
    Cheers
  2. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    LG makes a CURVED 21:9 3440x1440 34" screen ;)
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Mixed resolution triple screen gaming is possible* via Eyefinity but IIRC still not possible with Surround (this may have changed with the 9xx launch).
    *ALthough I don't know if your configuration would work.
    Bare in mind you are going to want some serious GPU horsepower and VRAM behind these screens to max out your games (at a decent framerate). You are looking at over 12MP to push (or double my Surround setup / 50% more than a 4K screen).
    980SLI / 290X CF or ideally Titan (Black) SLI (for the 6GB of memory) would be the minimum I would be looking at to drive this sort of resolution.
  4. pcb
    2 Feb 2014
    The Curved one looks awesome but that would be another 350€ on top for a feature i don't really like.
    Just double and triple checked the driver release notes and found nothing new about Surround gaming apart from the G-Sync support. Sadly most Information on the Nvidia website is still for the 6xx series :wallbash:
    I guess 21:9 with 16:9 on each side won't be possible with todays Nvidia drivers :( so now I still could go for 3* 16:9 or 3* 21:9 if supported.
    I'll ask the guys over @ Nvidia if 3* 3440*1440 in surround is possible and give you guys a feedback asap
  5. Mister_Tad
    27 Dec 2002
    I get it when compared to a single screen, but surely with a 3x screen setup you would be wrapping them around anyway, so seems curved would be ideal?
  6. wolfticket
    19 Apr 2008
    I wish I had problems like this :)
