Windows Svchosts Question
Discussion in 'Software' started by Soulmage, 30 Dec 2006.
  1. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Has any one found a good guide that shows how to trim out some of the svchosts.exe entries in taskmgr? I have 5 right now and i know some can't be removed (like the one running DCOM and such)
    P.S. - Yes i :search: btw :hip:
  2. quack
    quack Minimodder
    6 Mar 2002
    AFAIK You can't touch svchosts. It's incredibly important to the running of Windows.
  3. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Svchosts itself is just a wrapper AFAIK. there are other proccesses under it that are running (Dll's mostly) that you can see if you do a tasklist /svc under Windows xp pro cmd prompt (doesn't work on xp home unfortunatly)
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Oh I didnt know about that one! Nice
  5. lcdguy
    lcdguy Minimodder
    25 May 2004
    if you want to find out what processes are running under your svchosts in task manager get process explorer by winternals.
  6. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    The process explorer is pretty nice. Unfortunatly it still only shows the process as svchosts and not the actually dll's its running
  7. quack
    quack Minimodder
    6 Mar 2002
    Right click on an svchosts entry, click Properties, then click Threads. There's the dlls.
