PSU Swapping out corsair psus
Discussion in 'Hardware' started by panda_uk, 22 Apr 2015.
  1. panda_uk
    panda_uk New Member
    30 Jan 2015
    Can I swap out a corsair RM1000 for a corsair AX1200i or HX1200 without having to change all the cabeling in my case.
    thanks
  2. ak_2020
    ak_2020 Member
    22 Nov 2010
    as far as I can tell all the latest generation modular Corsair PSUs use the same cables, so you should be okay to just swap out the main unit...although why you would want to swap out a 1000w PSU for something bigger is beyond me!:jawdrop:
  3. panda_uk
    panda_uk New Member
    30 Jan 2015
    Cheers for the reply. I'm currently runnnng dual xeons and three 780 ti's. So I thought it safer to go up to a 1200w psu. Though currently my 1000w is coping fine.
  4. panda_uk
    panda_uk New Member
    30 Jan 2015
    Plus I want to cool a couple of the 780's with kraken G10's .
  5. ak_2020
    ak_2020 Member
    22 Nov 2010
    blimey! Have you considered buying your own power station to go with your new PSU? Might save you a few quid in the long run...:thumb:
  6. Big Elf
    23 Apr 2009
    Risky. Although the RM1000 and HX1200 are built by the same manufacturer the AX1200i is a different one. There's never any guarantee that the pin-outs are the same even from the same manufacturer so it's important to test either with a PSU Tester or with a multimeter. Get it wrong and you could say goodbye to a lot of expensive kit.
  7. panda_uk
    panda_uk New Member
    30 Jan 2015
    I think I'm going to ask corsair direct. I really don't want to get this wrong.
  8. JamesRC
    JamesRC Member
    5 Oct 2012
    If it were me, I'd still re-plug. You have a nice setup, I wouldn't risk it for 20 minutes work :).
  9. Kovoet
    Kovoet New Member
    26 Aug 2009
    They are different. You can check it on there website
  10. panda_uk
    panda_uk New Member
    30 Jan 2015
    Spoke to a corsair rep on their forums and he says you can swap these models out without changing the cables.
    Also if you look at the braided cable upgrade kits the RMs and HXis use the same kit.
    So this will save me some time, thank god.
