.swf not playing if not in html file
Discussion in 'Tech Support' started by John_Edward, 23 Jul 2007.
  1. John_Edward
    John_Edward What's a Dremel?
    21 Dec 2005
    So, I suddenly got this weird problem with my comp after uninstalling IE7 because it was bugging with nVidias drivers.
    If I go to youtube, newgrounds or any other place, flashfiles work correctly.
    But if I try to open a .swf file, well..
    And if I try to open it in Media Player Classic... ( This one came AFTER reinstalling Flash & Shockwave, MPC worked before :< )
    I have tried reinstalling Flash and Shockwave players from Adobes site, tried using Internet Explorer 6, which also has the same problem as Firefox, and reinstalling Firefox.
    But nothing has worked.
    I also tried to use "Swiff Player", but it says that Flash Player isn't installed.
    Anyone know what is wrong and how to fix it ?
    I have Firefox 2.0.0.5, Flash Player 9.0.47.0 and Shockwave 10.2.0.022.
  2. John_Edward
    21 Dec 2005
    Okay, after bearing with this problem for way too long, I came across this site - http://www.softwarepatch.com/internet/flash.html
    It says it is an "ActiveX" plugin, and as it is IE thing, and I don't use it, I thought maybe that was what went wrong uninstalling IE7.
    After downloading and installing it, MPC and Swiff Player started working \o/
    Firefox still wont play them, but that doesn't matter as I usually use MPC.
    ..So, it didn't fix it completely, but at least it works.
    If someone has the same problem, hope this helps.
