Swiftech MCX462 [ UK Store? ]
Discussion in 'Hardware' started by neuro, 13 Jan 2002.
  1. neuro
    neuro What's a Dremel?
    9 Jan 2002
    Im desperate to get this heatsink but cant find any UK stores that sell them, can only find UK store that sells the "MC" version only :(
  2. Guest-16
    Guest-16 Guest
    what's the diff?
  3. neuro
    9 Jan 2002
    Well, the MCX has thinner pins meaning that there are far more than the MC, which results in more surface area which can disipate heat much better. also, i cant remember the exact term they used, but the pins a kinda spiraled which seems to help the cooling. overall, its a better heatsink.
    c'mon chaps, we need to find these heatsinks. im not ordering from a us based store, i've already tried and they where gonna kill be on postage. :(
  4. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    I think you mean helocoid.
  5. Guest-16
    Guest-16 Guest
    Ooo are they "ribbed for extra pleasure" too?
  6. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    Basically. :p:)
    To be honest mate, if your mobo can take it, the Alpha PAL8045 is better value. In performance the alpha is between the two swiftechs (better than the MC, not as good as the MCX), but is cheaper than either. I'm unconvinced by the build of the swiftech though, as I've heard that the pins aren't very solidly attached to the base (to the point where some can fall out, and some can easily be pulled out). The Alpha is SOLID.
  7. neuro
    9 Jan 2002
    the alpha was my first choice, but as it doesn't fit my asus 27v266-e raid board without having to shave the corner off, which i was prepared to do. i decided to get the swiftech :D
  8. Tim S
    Tim S OG
    8 Nov 2001
    Bar the copper insert in the base :p :rofl: ;)
