Electronics Switch amp rating
Discussion in 'Modding' started by Lazlow, 23 May 2006.
  1. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    I have a funny feeling that I've purchased the wrong switches.
    I've got 5 x Sub-Miniature Toggle Switches similar to these.
    They are rated as:
    2A 250Vac
    5A 125Vac
    5A 30Vdc
    Will they be suitable for turning on/off fans (120mm and 80mm) along with lighting within a case?
    I'm no electronics expert, so I don't know if they will be suitable or not.
  2. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Those are plenty good.
    Switches are rated for the maximum current (amps) and voltage (usually ac or dc) that they can safely handle. PC fans and lights are nowhere near that power level, so you're all set.
    btw, so long as you're not dealing with very high power circuits, there's no difference between an ac or a dc rated switch.
  3. Lazlow
    8 Aug 2003
    Thanks for the quick feedback. Good to know they are suitable, as the 10amp switches are quite a bit bigger than these - I chose these for the small size.
