Modding Switch Modding
Discussion in 'Modding' started by Guest-23315, 10 Oct 2006.
  1. Guest-23315
    Guest-23315 Guest
    I was wondering wether or not using one of these wold be a good idea for a ON/off Switch....
    Id wire it so that the Primer swtch had to be on before the main switch ect...
    any opinions ?????
  2. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    Really nice. I want one.
    Maybe put a led behind the red thing as a power led
  3. Guest-23315
    Guest-23315 Guest
    yeah, thats onw of the things i thought about doing
  4. T.M.P
    T.M.P New Member
    23 Apr 2006
    I used a panel that were similar to that on one of my older PC.
    the only thing you should think about are how many volt the light need.
  5. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    You'll need a power line for light with right level resistor, normal power switch wires. You could make your own nicer and cheaper. Just get a SPST switch latching type that is nice. And a momentary non latching SPST switch.
  6. SIMSY
    SIMSY New Member
    7 Sep 2006
    That would be great for my Project Carbonite. :D
  7. Guest-23315
    Guest-23315 Guest
    i think im gonna invest in one... :rock:
    when i get it, i'll hopefully put up some pics of the unit itself.
