Electronics Switch - On/Off, not momentary...
Discussion in 'Modding' started by phinix, 4 Apr 2008.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I'm looking for small and nice on/off switch, not momentary, the one that will turn loop of leds in my case - I think its called latch or sth:)
    I don't want to use vandal switches, they too big. I need something like these, but these are momentary.
    I want them to be small - kinda micro-switches - sth like in phone set. I hope you know what I mean....
    Where could I buy this kind of switches? In UK???
  2. swift_wraith
    swift_wraith I love you Pig.
    3 Mar 2008
  3. phinix
    28 Apr 2006
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Press the tab marked "Specification".
    Which bit is unclear? :confused:
  5. badders
    badders Neuken in de Keuken
    4 Dec 2007
  6. phinix
    28 Apr 2006
    Panel cut-out: 62mm
    Bush length: 85mm
    Body size (excl tags): 175 x 82 x 13mm
    Button size: 8.5 x 10mm diameter
    exactly this part is unclear...
    so what is overall length of that switch? what is tag, bush?
    So body is the part below button, right?
    So it is: button8.5mm + body 17.5mm + those tags (which I think they might be those small metal part that you solder cables to, right?) Should I add bush length?
  7. vaderag
    vaderag I know what a Dremel is...
    19 Jul 2007
    Slightly off topic, but if you were to use a non-momentary switch for your power button on your comp, what would happen? (i assume that momentary means it pops back out like all pc case switches are usually).
    Would it just act like if you held the power button down (i.e. off after 4 secs)? Or could you set it up to shutdown the comp as normal? As far as i remember, there are only two power options in my BIOS - one for 4 seconds, and one for instant...
  8. swift_wraith
    3 Mar 2008
    in q&a tab on maplins link:
    Q) Please can you confirm the dimensions as it is listed as a miniture switch but the dimensions make out that it is 17.5cm by 8.2cm and with a panel cut out of over 6cm? - Rich
    A) the decimal point has been missed out, it should reed 17.5mm 8.2mm and 13mm cut out is 6.2mm and bush length is 8.5mm
    Q) It says rated as 3A/240v, but can this be used for 12V in a model railway? - Tim Blazey
    A) Yes the product does support that.
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    http://www.mouser.com/catalog/specsheets/SC-500001.pdf
    Maplin seem to have some of their units wrong. :lol:
  10. phinix
    28 Apr 2006
    that's all fine, but I still do not know what is what - bush, tag...
    SHould I just add them all together?
