Electronics Switch problem sorta PLEASE please help me please!
Discussion in 'Modding' started by Bboy_Jon, 11 May 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    OK well this is how i hooked up my switch for my lcds power adapter (note it runs off 120v)
    ok well im retarded, and so i made the mounting hole for the switch but it is waaaaay to tiny for the adapter to fit through so i need to de solder it and make a quick and easy way of connecting, disconnecting, so question is, can i use a molex?
    would this work?
    the molex wires can handle 120v right? (its a molex and wires from a psu)
    so is that right? that would work right?
    please help me!!
  2. hitman012
    hitman012 Minimodder
    6 May 2005
    I assume that grey wire in the second picture is the negative lead. If so, that looks right to me.
    The molex wires shouldn't need to handle 120v if that's a power adapter - you should only be getting low voltages on that side of the transformer.
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya it can handle 300v, someone said they can handle 1200kv or somethin lol should be good
  4. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    yes, if the first pic does work, the second pic will work
    however, i doubt your LCD runs off 120v, considering that there is an AC adapter. if it did, you would not need it. so there is a DC voltage, most probably between 3 and 30 volts going to your LCD thrugh your switch, not 120v AC
  5. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    o ya my bad, it runs offf 7.5 but its connected tto the 120v outlets
