Symantec Anti-virus
Discussion in 'Tech Support' started by Ryu_ookami, 7 Oct 2008.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    Ok, a friend of mine is trying to remove symantec anti-virus from his PC but it wasn't in add/remove programs so he started in safe mode and deleted it. Now however when ever he right clicks a shortcut he gets a message saying
    "please wait while windows is configuring symantec anti-virus"
    thing is he is now using AVG free edition and he wants symantec GONE!!!!
    I'm presuming its the reg entry or that symantec leaves an auto installer behind somewhere.
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Google is your friend.
  3. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Firstly, i'd advise against ever running anything from symantec that isn't ghost, the only decent program they do :hehe:
    For slightly more useful advice though:
    start -> run -> msconfig
    disable any startup processes / services that look like they have anything to do with symantec, then reboot and try it
  4. Silver51
    Silver51 I cast flare!
    24 Jul 2006
  5. Ryu_ookami
    11 Mar 2004
    You're right google is my friend but if you don't have anything useful to post please don't post at all (especially as I'd already tried Google as I would have expected anyone to do before posting here.)
    already done that but thank you.
    thank you
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    'remove norton' and 'remove symantec anti-virus' both give the answer as first hit, what have you been searching for? :confused:
  7. Ryu_ookami
    11 Mar 2004
    symantec removal tool unfortunately when i try all the procedures from the 1st few of the google results its tells me that symantec version 9 or later is installed and that I need to remove it from add/remove programs before it can remove the program.
    but its ok now I've talked him through manually editing the reg and fixed it. :)
