News Symantec glitch breaks World of Warcraft
Discussion in 'Article Discussion' started by CardJoe, 7 Jun 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    People still use anti-virus software? :O
  3. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    Why does everyone in WoW have a beard? even the women!
  4. shanky887614
    shanky887614 What's a Dremel?
    13 May 2009
    are you crazy you need an antivirus to get rid of them, if you dont have one you should install one
    its just one of those things you need to do its like going to the docter we may not like it but we have to go if we are feeling ill
  5. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    Norton is a virus its self.
    I've had the damn thing try so many times to install its self and it even succeded once when I wasn't being careful when installing some new software.
  6. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Norton has been one to avoid for years. But it classing WoW as malware is great lol.
  7. theflatworm
    theflatworm Gordon Freeman's Crowbar
    22 Jan 2010
    I used to work at PC World, and whenever someone came in with a malfunctioning PC, the first thing the tech people did was ask if they had Norton installed, and if so, tell them to uninstall it.
  8. B3CK
    B3CK Minimodder
    14 Jun 2004
    Norton AV isn't as bad as it used to be. The 360 edition is more resource hog than the standard AV edition; but they have gone a long way in the last couple years.
    I think it might be time to do a performance review of how much the different AV products hurt performance in windows, in-game, and web surfing. While there are plenty of sites that track how well they detect something, not many offer performance stats.
  9. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Lmao and isnt it pcworld that sell norton at a discount with every new PC ;)
  10. aussiebear
    aussiebear What's a Dremel?
    13 Nov 2008
    Here's a few facts about AV solutions.
    (1) You are immediately on the defensive when you use it. Meaning that you will ALWAYS be reacting to (one step behind), malware writers.
    (2) Malware variants outnumber AV signatures. (The time required to get a malware sample; analyse; create a signature; test it; and then push out to customers; cannot match one's ability to push out 10 to 20 malware variants in the same period of time. Thanks to scripting and automation tools!)
    (3) AV does NOT protect you from system or application specific exploits. (That is, they do nothing if malware specifically goes after something critical as a Windows service or something like Adobe Flash or Reader.)
    (4) AV solutions are profitable because the whole business relies on user ignorance of what is already built-in Windows and poor computing habits. (Like using pirated software, allowing any random executable from the Internet to run, etc.)
    (5) AV solutions are often poorly implemented and can be a potential security issue themselves! ie: Believe it or not, some AV solutions out there use specific hooks to the Windows Kernel such that it makes them vulnerable to certain types of attacks.
    (6) AV solutions can kill your system or cause you major inconvenience IF the AV developer stuffs up their quality testing process with their signature updates. ie: The McAfee Anti-Virus Update which killed Windows XP computers back in April wasn't an accident. It was an eventuality. McAfee never tested their signatures on XP systems in the first place! (Unsurprisingly, its happened with Symantec!)
    So what's the alternative? Prevention. Not reaction.
    This is in the form of sound computer usage that is more security aware, and reversing the Allow-by-default concept of Windows.
    To put it simply; Allow-by-default means you can run any executable from anywhere. Good or bad; regardless of where it came from! This is the fundamental issue at hand.
    The reason for this approach is because of convenience to end-users. But its really flawed from a security perspective.
    The prevention approach is to reverse this to Deny-by-default. This means you deny everything at first; and only allow to run things that are known to be safe or trusted. (So you restrict the running of software you actually need and nothing else.)
    So for something like drive-by download attacks; they don't work on a Windows system that is set up with the Deny-by-default principle. This is because you are denying all foreign executables!
    Malware is just software designed/written for a specific purpose; by denying the ability to run software that isn't from a known/trusted source; infection cannot occur!
    The catch?
    You must have a Windows version that supports Software Restriction Policy or AppLocker.
    (NONE of the Home Editions have this feature.)
    ie: You'll need to have one of the following...
    => Windows XP Professional
    => Windows Vista Business/Ultimate/Enterprise
    => Windows 7 Professional/Ultimate/Enterprise
    For details, see here...
    => http://www.mechbgon.com/srp/
    The overall point?
    Don't waste your time and money on researching, investing, installing/maintaining AV software on your system. Spend the time in gaining knowledge/understanding and instill new habits of prevention. Because it saves you time, money, and your system resources in the long term.
    You don't need AV when you know and practice sound security principles in computing.
    This is what every experienced Linux, BSD, etc user knows. Only a minority of Windows users know this. The majority do NOT.
    And if you live your life correctly with regular exercise, healthy diet, and other proper measures that prevent sickness and injury; you wouldn't need to go to the doctor in the first place!
    Is it starting to sink through?
    => Prevention is better than cure.
  11. javaman
    javaman May irritate Eyes
    10 May 2009
    Norton, doesn't surprise me. Like AVG and McAfee its useless, tho it has to be a first for it to actually detect something! Guess thats progress. Prevent certainly is better than cure but most anti-virus fail in that area. MSE and Avast have been the only two that i've used that actually protects the PC and has a good scanner if something does get on.
  12. Guinevere
    Guinevere Mega Mom
    8 May 2010
    That's but one view to take, and one that assumes that everyone with a windows PC is cable as being as good at "prevention" as an "experienced Linux, BSD, etc user"
    Can I give you a couple of examples of when it may be a good idea to have a good AV solution installed (Note I said good - I'm not going to get started about that definition)
    - A PC owned and managed by competent users, but not experts (EG my parents)
    - Owned and managed or just used by a responsible kid (Like many familes)
    - Any use of downloads of suspect legality. (Like many many people)
    Prevention is always better than a cure, and a good AV solution will prevent a lot of people from having problems.
    It's great you don't need one (hey I don't have one on my mac) but discounting all their possible worth to EVERYONE means their real purpose hasn't sunk in for you.
    An AV solution is aimed specifically at those that cannot put in place a 100% rock solid prevention system, or where a lapse in procedure is possible.
  13. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Common sense and MS Security Essentials has seen me virus free for ages. Many people get viruses because they're silly and download stupid things: if someone is going to run an infected file, you need an AV to get rid of it.
    Education is the cure, but it's nigh on impossible to educate everyone.
  14. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    ha awesome, I use MS Security Essentials, works well and is pretty light way and free.
  15. tristanperry
    tristanperry Minimodder
    22 May 2010
    LOL! I definitely see the funny side! Norton really is junk though; I used it before and really disliked it. Definitely a bad piece of software, IMHO.
    Anywhoo, aussiebear makes some very good points. I agree that if Windows moved away from its "Yay, lets allow everything to run automatically!" stance then it'd go a long way towards tackling some of these problems.
  16. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    And during this time linux user are having fun thinking that PC user pay a programe to sop another programs they are paying for.
    Jokes aside new technologie for antivirus would be great but the most important is people to be prudent and do a few Relocation every years. I think there is no perfect way to keep a system clean.
  17. Tele1952
    Tele1952 What's a Dremel?
    30 Dec 2009
    Eset. Win. Bosh.
  18. crazyceo
    24 Apr 2009
    The main problem with that is Microsoft gets dragged into court again for not freely allowing its users to goto/clickon/read/open/download whatever the users intentionally or unintentionally wants to.
    A habitual drug user unfortunately has an overdose of whatever he/she has taken. The doctors and nurses work hard to revive the user and clear the users system of all toxins and when recovered release the user from hospital with the clear warning that they were lucky this time and to seek help. The user gets home and thinks "Boy, I was lucky this time. I better be more careful!" and goes to sees his/her dealer for more drugs.
    The moral of the story? Stop downloading PORN!!!!!!!!!!!!!!!
  19. [- pio -]
    [- pio -] What's a Dremel?
    2 Feb 2004
    With people calling WoW a disease for so long, I'm almost surprised that antivirus programs haven't started "curing" it before now :lol:
    On a related, and ever-so-slightly creepy, note: As many here have said, prevention is better than cure. Thus, the logical next step will be vaccinating people against WoW, kinda like with this guy :worried:
  20. rhuitron
    rhuitron Bump? What Bump?
    15 Aug 2006
    HA! Awesome!
Tags: Add Tags
