Electronics Synaptic Touch pad
Discussion in 'Modding' started by Soulmage, 12 Jan 2006.
  1. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    OK well i have this touch pad from a compaq laptop that i killed (long story)
    Basically from what i have found out is that this can be interfaced with a PS/2 port.
    Info here - http://www.synaptics.com/decaf/utilities/tp-intf2-4.PDF
    How ever that document does not show my model which is a TM41PDG353-1.
    I have figured out what most of the model number means from the pdf but my problem is this:
    It does use a 6 pin interface and i was easily able to determin that pin 4 was ground. I could use some advice on how to trace down the other pins if possible. I will get pics of it up in about an hour (once my cam battery is charged :wallbash: ) but any advice in the meantime would be helpful.
  2. elctroJunky
    elctroJunky What's a Dremel?
    9 Jan 2006
    Erm... take a multimeter and measure the signals that come from the laptop...
    well you killed the laptop, but i think (if you didn't just blow it up) the VCC an GND on the touch pad connector might still be active.
    Once you've found them you could try the other connections out with a computer (as these must be signal lines, and there's only a small chance you could damage anything by connecting the signal lines the wrong way).
    If there's no reaction from the touchpad connector on the laptop anymore you can still go the hard way and trace back the lines to their origin on the mobo. That may give you an idea on how the touch pad has to be connected.
    Any other method I can think of uses trial and error that might kill your touch pad.
  3. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Ok , sorry for taking so long but here are the pics
    The cable connection blocks were temporarily removed so that i could see the traces better. The six pin connector is what would connect to PS/2.
    Top
    Bottom
    electrojunky, heh the board is really fryed, and i tried tracing the motherboard but .. yeah, thats a serious rats nest and i get lost VERY easily :/
  4. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    hrmm .. from 37 to 52 views and no ideas?
  5. Soulmage
    Soulmage Minimodder
    20 Oct 2005
    Never mind, finally got it to work .. and great might i add.
    if any one was wondering (though i doubt it) pin6 = vcc, pin 5=data, pin4 = gnd, and ping 3 = clock . (though i honestly can't remember which was which between data and clock. if you try this and it doesn't work, just switch those two.)
  6. ciccillover
    ciccillover What's a Dremel?
    1 Mar 2007
    I'd like to do the same with my touchpad (from a Presario 700). It has similar part number (lacks the final "-1"), but a different 4 pin connector.
    Pictures are no longer online, can you send a copy via e-mail? My address is just like my nickname, just add @libero.it.
    Or any other kind of help or suggestion is welcome.
    Thanks in advance.
    P.s.: mobo no longer available
  7. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Worst case, you should be able to follow the traces and determine vcc and ground. That would leave data & clock, giving you a 50% chance of working 1st time or simply reversing the two.
  8. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Did something similar over here: http://forums.bit-tech.net/showthread.php?t=121291
    Not all the touchpads use the same pinout, there is a pdf I linked to which has the pinouts for all the major synaptics touch pads. Glad you got yours to work. Still trying to figure out what exactly to do with mine.
  9. agent420
    18 Apr 2006
  10. mattthegamer463
    26 Nov 2004
    I am also trying to do this with a touchpad from a Presario 700, so far I haven't found any data or even a part number, so I'm going to try and ID the 4 pins myself. I'll post any findings.
  11. Warrior_Rocker
    26 Jun 2005
    The +5v and the ground should be quite obvious even if the touchpad is not labled. I knew a dead give away for the +5v line was a resistor placed between it and the controller. The ground was also fairly obvious as it connected to the gold dots around the back of the touchpad. If didnt have the datasheet it would have taken me one more try to get the data lines. No harm can be had by switching the clock and data pins. If it doesnt work one way It should work the other.
    That is to assume of course that your touchpad is ps/2 in nature. I would be willing to wager it is. Then again you never can tell with laptops these days.
  12. mattthegamer463
    26 Nov 2004
    It has a 4 wire ribbon cable coming out of it, so unless its a proprietary compaq stupid thing then its PS/2.
  13. Chomiho
    Chomiho What's a Dremel?
    28 May 2011
    Hi everybody,
    I'm trying to interface a Synaptics T1005, but I'm not sure which pins have which function.
    This video here would be helping if it wasn't a slightly different modell. Anyone's got an idea?
  14. pankajsingh
    pankajsingh What's a Dremel?
    17 Mar 2012
    i am trying to interface synaptic touchpad tm41pum1311-2 with atmega644 microcontroller.I have the pinouts of the touchpad(1,2-clk 3,4-data 5,6-left switch 7,8-right switch 9,10-ground 11,12-+5v). I am not sure its working or not. when i connect give 5 volt input between +5v pin and clk-pin, i get 5 volt output at clk-pin and data-pin. Is this normal?
