News Synaptics introduces 10-finger multitouch
Discussion in 'Article Discussion' started by Sifter3000, 23 Jul 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. Matticus
    Matticus ...
    23 Feb 2008
    I am just thinking of a dual screen netbook/small laptop. Like a netbook/small laptop DS, bottom screen can be an onscreen keyboard and also display what you want.
  3. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    I won't buy in until it supports at least 11 points! Got too think of those Polydactyly's out there.
  4. Bonzo45
    Bonzo45 Ex CPC
    25 Apr 2009
    Clever piece of hardware, not sure about it's uses though! Perhaps 8 inches is too small for two player games! Maybe it could spawn a new touch screen handheld gaming console, put 10 points is a bit OTT IMHO.
    Surely you can't coordinate 10 of your fingers to do different things on the screen, the technology is too good for the human brain.
  5. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    10 finger tracking on smart phones? Nice but how would I hold it then?
  6. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Sounds fun and worth a look, too bad you'll get fingerprints all over your screen though >.<
  7. p3n
    p3n What's a Dremel?
    31 Jan 2002
    How would you keep your palm from touching it for x hours usage? Terrible...
  8. Isitari
    Isitari Minimodder
    6 May 2009
    Minority Report here we come :D
  9. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    you can just wipe it if it gets dirty though :), I wont be surprised if ways are found to lessen this problem in the near future, fingerprints for me is the most least problem i will have in multi touch devices
  10. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    How do you see the screen with 10 fingers in the way?
    I would not be a fan. Virtual keyboards on phones these days are enough of a pain. I would have to see how that would translate to typing out an actual document rather than a 140-character text. I need my physical buttons.
  11. dicobalt
    dicobalt Minimodder
    21 Mar 2009
    The only personal use I can think is for RTS games. The lack of feedback and tactile variation makes it limited in use. There is place for multitouch sensors but that is on a separate device, not in the screen itself. Think of the touchpad on a laptop only much bigger and far more accurate. I would have it slide out from under the keyboard and be at least 3x larger then a laptop pad. As you move your fingers on the pad you can see overlays on the screen representing fingers. This implementation would be cheaper, simpler, and your hand wouldn't be obscuring the view of the screen while causing fingerprints. Furthmore you wouldn't get karate kid wax on wax off cramps and you wouldn't need to stare downwards at the table like an idiot with bad posture.
  12. I-E-D
    I-E-D Minimodder
    28 May 2009
    On screen keyboard sounds cool, cos you could drag the little keys around to spell words, and to get the best config for you!
  13. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    no-one else think that this sounds like the potential tech behind a future Optimus touch gaming keyboard?
  14. Ross1
    Ross1 What's a Dremel?
    15 Feb 2009
    with a finger or thumb on the screen, a large part of it is already blocked. this just seems to be a way to completely obscure any possible view you have of the screen, which will lead to blind fingering. this is often quite messy, and isnt a very pleasant experience.
    obviously if you are using your 10 fingers and 2 thumbs on the screen, the device will be held in your mouth. some people may be able to hold it with their feet, and anyone who has an extra arm will be ecstatic that they finally have a use for a previously unneeded limb.
  15. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    How is this news?
    I thought Microsoft Surface was able to handle 50 users at a time.
  16. perplekks45
    9 May 2004
    TMI, thank you very much. :p
    You REALLY must be special!
  17. Gareth Halfacree
    4 Dec 2007
    Microsoft Surface is not a capacitive touchscreen. Nor is it possible to integrate Surface into a portable device - it requires cameras and infra-red emitters along with a projector.
  18. Timmy_the_tortoise
    28 Feb 2008
    Right. I actually knew that, I guess I just forgot. It was a bit stupid of me...
Tags: Add Tags
