Hardware Synology DS212j and DSM 4.0 Review
Discussion in 'Article Discussion' started by brumgrunt, 4 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. jamalsid
    jamalsid What's a Dremel?
    1 May 2009
    Are the Synology single bay NAS boxes worth getting? I really want to get a NAS box but don't want to spend much money and I also don't need masses of storage space.
  3. stupido
    stupido What's a Dremel?
    30 Nov 2009
    That is the question that I have in mind too... Actually I would consider dual-bay NAS just because you can have RAID config if one of the HDD decides to take a break...
  4. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Ok, I'm a Freenas user, with access to lots of old pc's, but I do see the point of having something like this now. It's easy, relatively cheap, quiet and power efficient. If I ever get 100Mbs broadband (which apparently is on it's way in a year or two in my area) then I'll move everything to the cloud, but I can see the sense...
  5. TheLegendJoe
    TheLegendJoe Syntax error
    28 Oct 2010
    Noooooooooooooooooooooooooooooo
    I've got a 4 bay Synology NAS, I only use two of the Bays at the moment (my data requirements haven't gone over 3TB yet, but I have raided up 2 3TB drive...) Bu never get a single bay NAS, unless you can back it up all the time to somewhere else!
    And after a week, you'll be glad you've spent the extra money, I use my NAS all the time, I use it for music from work, photos for the family, and all my DVD's and music collection is stored on there, accesable from anywhere! For instance, if I want to carry on watching a tv series or movie with the GF when I go to hers, I just log in and can stream the content or download it to her laptop, easy peasy :)
  6. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    Why don't you just move in with her?
  7. runadumb
    runadumb What's a Dremel?
    20 Jan 2010
    I have a DS211j and have half assed tried to set that ezcloud function but have so far failed. I will be trying again today with this info, thanks.
    Do you know if that function extends to the DSfile Android app? That is the main reason I want it working. I never could get that working either.
  8. TheLegendJoe
    28 Oct 2010
    It takes a whole to save up for the £1,000,000,000,000 deposit for a house these days!
  9. greypilgers
    greypilgers What's a Dremel?
    23 Jan 2011
    This might be a silly question, in which case please feel free to one word answer, or direct me to the answer link, but if you buy one two bay NAS, can you also connect a second one to the same ethernet network and use both at the same time? The reason I say that is I want to get this one reviewed here, and will likely want another one in a year or so - I don't want the instant expense of a four bay NAS and the hard drives, but over the course of a year or so the extra of buying two is minimal.
    Cheers!
  10. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    No no no no no no.
    Having lots of useless crap installed beforehand is NOT a good idea.
    The variety of usage-cases that a NAS may be used for is FAR too wide for bundling every "App" (they're packages, not apps, dammit!) in ahead of time. I don't want to have to manually uninstall Bit-Torrent DLNA, and whatever other crap that they decided people want after I buy a piece of hardware.
    Again, this seems to be a case of you reviewing this with a different usage case then it's designed for. This (and NASes in general) are designed to be stuck in a closet, or up on a shelf, and basically never looked at. Franky, having USB at all is a bit unnecessary (though it's nice to be able to add an external HD at a later point).
    The instructions may not be very good here, but this is actually a far better design. It means that the ONLY information Synology has about you is your IP. Everything else is stored locally. As such, it's a lot more attractive to people (like me), who are uncomfortable trusting a outside company with their data, particularly given the littany of recent security breaches.
  11. timmehtimmeh
    timmehtimmeh Minimodder
    2 Jan 2005
    I love my D's 212j. Its perfect for home use. Buy it with a to link 5 port Gigabit switch and 2 of those to link 200 or 500mb adapters and hey presto.
    70mB access to my files on my PC through the switch and plenty of good connection to the router through the power line. I have 3 more for media streamers now too.
    I might have a play with the audio station now
    Having the same problem I had with 3.2 again now. The nas won't sleep. Hdds won't atop spinning.
  12. timmehtimmeh
    2 Jan 2005
    PS. Why would anyone put their nas on an 802.11n connection in a shed? Seriously? You would cut all access to the drive back to sub 100mb cat5 networking.
  13. Combatus
    16 Feb 2009
    If you're not fussed about speed and just want a way to backup data outside your house in case of fire, theft, flooding or whatever, its a useful way to do it and probably faster than using powerline adaptors. I know several people who have done it.
  14. wyx087
    15 Aug 2007
    along with DHCP capabilities, you could actually use the NAS as a wireless access point!
    meaning you could just carry the NAS everywhere (after configured it) then plug in the power and USB dongle for instant wireless access to your data!
    DSM 4.0 is simply awesome. :D
  15. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Actually, Scan (that would be bit-tech's "preferred partner") is listing several Hitachi 4TB drives:
    http://www.scan.co.uk/products/4tb-...sata-iii-6gb-s-7200rpm-64mb-cache-8ms-ncq-oem (in stock)
    http://www.scan.co.uk/products/4tb-...sata-iii-6gb-s-5400rpm-32mb-cache-8ms-ncq-oem (pre-order)
    http://www.scan.co.uk/products/4tb-...00-35-hdd-sata-iii-6gb-s-7200rpm-32mb-8ms-oem (in stock)
  16. TehKrak3n
    TehKrak3n What's a Dremel?
    19 Jan 2011
    DSM 4.0 is quite awesome .. very user friendly
    Out of all the pre-built NAS - I think Synology is the most expensive though - but worth it
Tags: Add Tags
