Storage Synology NAS
Discussion in 'Hardware' started by Kovoet, 9 Sep 2013.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Anyone got and if so any advice would be appreciated. Got mine today and taking my time setting it up.
    If any of you have any useful tips please let me know. I have the DS212+ 1 BAY
  2. droyden
    droyden What's a Dremel?
    6 Sep 2011
    how come its only 1 bay? or you plan to only put one drive in it?
  3. Kovoet
    26 Aug 2009
    Only one drive bud
  4. droyden
    6 Sep 2011
    I'd put another drive in it and raid1 it :p
    Are you planning on just using it for shared storage?
  5. jinq-sea
    15 Oct 2012
    Kovoet likes this.
  6. Kovoet
    26 Aug 2009
    Awesome this is what I want thanks bud
  7. 2tricky
    2tricky What's a Dremel?
    12 Feb 2011
    Have the exact same model as this (upgraded from a DS-106), and have to say it's been superb.
    Is fast enough for my needs, and streams TV/Movies to my WDTV faultlessly. Highly recommended! The only thing I did was change the fan, as the one that came with it seemed to be too noisy to my ears. Good choice!
  8. wyx087
    15 Aug 2007
    I've got the Ds213j, budget one but with floating point processor. Much speedier than the 410j I've had. It's main purpose is to serve photo with Synology's photo station, so FPU works wonders. It lives in my bedroom and it is soooo quiet, the unit can be left on all the time and idles at 3w, similar to most TV's off usage.
    I thought video station can already handle DVB recording?
  9. Kovoet
    26 Aug 2009
    Thanks guys. So far added all my music and drivers. Linked up all my tablets and phones as well
    Sent from my GT-I9505 using Tapatalk 2
  10. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    I did not know this. Is there still room to use the second USB port with a USB TV tuner? I'd want it as a print server too.
  11. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    You can use that software on the Micro Server too, I guess.
    I still can't decide between the two.
  12. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I've had a Synology DS212j since January. Brilliant bits of kit!
    I use the Cloudstation app so I have a personal cloud that works the same as Dropbox but private. There's even an iphone app for it.
    The 2-stage login for the web UI is quite cool.
