Sys maintenance a pain in the neck
Discussion in 'Tech Support' started by mon3r, 8 Jun 2006.
  1. mon3r
    mon3r What's a Dremel?
    7 Jun 2006
    Hi Guys.
    Am finding it such a bother to actually schedule all these system maintenance tasks and to top it all find that some of them dint run properly. Is it just me? Or do you guys enjoy this? I mean imagine you discover in the morning that the script never ran!
  2. Glider
    Glider /dev/null
    2 Aug 2005
    First, Welcome to Bit-tech!
    And second, Come again...? I don't understand what you mean...
  3. mon3r
    7 Jun 2006
    huh ! I meant I find is really hectic to schedule task for maintenance programs, like defrag, scandisk, disk cleanup. Then virus updates, windows updates, spyware updates, which have to be done is certain interval are hell of a job. Currently I do it manually and sometime you see most of the task would not have started or completed properly. So what is that you guys do in this case ??
  4. Krikkit
    21 Jan 2003
    Don't worry about it. You only need to defrag once in a while, scandisk too. Set your virus update to do it at any time, and most of them simply update next time you connect to the web if they fail.
    Set windows updates to automatic download and ask before install, so you know what you're getting. Spyware updater just update before you use it.
  5. Glider
    Glider /dev/null
    2 Aug 2005
    Sorry for my misunderstanding, lets blame it on the exams ;)
    And, like Krikkit pointed out, Windows updates on auto, with asking, most anti-virus and anti-spyware solutions come with their own updater,...
    And defrag and scandisk when you notice it getting slow;)
  6. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Leave your PC on through the day when you go to school/college/work and then when you return voila, thats what i do for my PCs
  7. mon3r
    7 Jun 2006
    Hi all,
    Thanks for ur replies.. i guess to keep the system in good shape, one cant avoid any of these things. Thanks for all ur replies.. :) i do defrag and disk cleanup regulalry, just that it takes so long and sometimes when i leave the defrag on waking up i see it has stopped at 4% or so.Things are fine now.thanks.
