Windows system cleaner software?
Discussion in 'Software' started by riggs, 8 Dec 2003.
  1. riggs
    riggs ^_^
    22 Jul 2002
    hey y'all
    anyone know of a good (free) system clear (ie, registry cleaner, dead shortcut remover, temporary file remover etc etc)...
    i'm always downloading new software, trying out, then uninstalling it, and i tihnk it's time to clean out my system...
    ta
    matt
  2. fump
    fump What's a Dremel?
    14 Aug 2003
    its not free but i like system mechanic. it does all you want and it even has a a secure delete function that can overwrite the data 10 times (on the version i have), which is stronger that government standards which is 7 times, apparently... works just like recycle bin.
  3. white modder
    white modder What's a Dremel?
    19 Sep 2003
    the recycle bin doesnt overwrite code
  4. Carbon
    Carbon Banned
    8 Jan 2003
    Windows washer
  5. fump
    14 Aug 2003
    its not the recycle bin, its called the incinerator and it works just like the recycle bin but better.
