System Clock
Discussion in 'Tech Support' started by Beevis82, 16 Jan 2008.
  1. Beevis82
    Beevis82 What's a Dremel?
    10 Nov 2004
    My friend has an E-Machine. well her computer does not keep correct time. so i went over to her house last night and change the c-mos battery and the computer was doing a good job keeping time. well today she emails me and tells me that the time is wrong again. i did bring the old battery home and tested it and the battery is good. does anyone have any ideas what could be going on? :wallbash:
    she has XP and is all up to date
  2. keir
    keir S p i t F i r e
    5 Oct 2003
    Try changing the time to somewhere in the near future and see what happens
  3. Beevis82
    10 Nov 2004
    and the computer was on all night if that helps. but if she turns it off it doesnt want to turn on. i think there is something wrong with the power switch
  4. Beevis82
    10 Nov 2004
    ok she changed the time at 12:12 it is now 12:51 she says it says 12:39
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's not an unusual problem. There's a script that will change the XP automatic time synchronization from the default weekly to daily (or even hourly), if the clock persists in drifting.
    There are also plenty of 3rd-party utilities that will do this, TClock Light adds some nice clock customisations.
  6. Beevis82
    10 Nov 2004
    cool. i might have to do this. the only bad thing is that she has dialup. but i will still have to check it out
  7. Beevis82
    10 Nov 2004
    ok at 10:25 her computer said 9:39 at 10:55 her computer said 9:49. any ideas?
  8. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Opposite problem to me, my clock speeds up every so often. I just reset the time manually and live with it (I don't consider it that important on my Windows box). Try the programs that have been posted. Save them to a USB stick on your own computer and then take that round. Should be okay then.
    Andy
