System Idle Process
Discussion in 'Hardware' started by NOMIS, 3 Aug 2005.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Anyone knoww what it is in my windows task manager and why it is using up ~90 of the CPU bit??
  2. Go4t
    Go4t i
    13 Dec 2003
    err idle... as in how much cpu isnt being used....
  3. Altron
    Altron Minimodder
    12 Dec 2002
    It's not supposed to do that. It's generally bad when it happens. Hit system idle process then hit end process.
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    System idle process should sit at ~100% load when the pc is idle. Its fine.
  5. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    *Cue Kameleon's sig*
    The System Idle Process is the measure of how much percentage of your CPU is idle. Good call :)
  6. NOMIS
    7 Jun 2004
    ohk i was just wonderin coz my comp seems to be runnin really slow lately
  7. Highland3r
    25 Jul 2003
    Scan for spyware, check msconfig for crap loading at boot, defrag the hdd.
  8. Mace
    Mace Ohh, it stings.
    9 Dec 2003
    1. Defrag
    2. Run a good av (I recommend AVG (Free))
    3. Run good anti spy/adware programs (I recommend Spybot S&D, Webroot spysweeper and adaware < those three together wipe out pretty much anything bad you can think of)
    4. Check the process manager for processes you don't want/need running (******** like Steam, QTTask(quicktime, not even needed) and whatnot generally tend to rape your system's full performance figure)
    5. Go to start> Run, then type in MSconfig and hit enter... this'll bring you to a system/boot config menu, go to the "Startup" tab, and disable unnecessary things in there such as the quicktime task (qttask..), and itunes helper and such.
  9. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Thanks, you just gave me a really good laugh :clap: :clap:
    And Zepher is correct, it's supposed to do that ;)
  10. NOMIS
    7 Jun 2004
    Hey cheers I'll do all that. Have you got a link for the AVG anti virus? I've got spybot I'll do that now :)
  11. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    HeeHee... I wonder how many n00bs killed it off... Made a good start to my day
  12. NOMIS
    7 Jun 2004
    Also, is there a website that explains all the processes so I can see if they are good or bad? LIke there are some with just random names and I dunno what they are.
    Thanks for your help :D
  13. Zephyr
    1 Oct 2004
    In fact there is, wonderful thing tbh. Been growing a lot in the last few years. Ready for it?
    www.google.com!!!11!1oneoneeleven
    And let the cheers from the crowd echo throughout the forums!
    :rolleyes:
  14. NOMIS
    7 Jun 2004
    Haha :D
  15. TMM
    TMM Modder
    12 Jan 2004
    just put in the name of the exe into google, 99% of the time the first few results are sites that have information on it, i.e. if it is harmful etc
  16. Mary Jo
    Mary Jo oh lolz
    13 Oct 2004
  17. fathazza
    fathazza Freed on Probation
    20 May 2002
    man, i can't believe people were so helpful in this thread.... or was it cos the pwnage was too easy :)
  18. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Id have to say "too easy not to" :D
