System locks ups after 8800gtx upgrade
Discussion in 'Tech Support' started by Caracortada_uk, 31 Aug 2007.
  1. Caracortada_uk
    Caracortada_uk What's a Dremel?
    29 Dec 2004
    Hi all. Just changed my 3d card from ATi X800XT to an Nvidia 8800gtx. Unfortunately when i first turn the system on it gets past the bios loading to the point the windows XP logo with the loading bar should appear, but i just get a black screen. Hit the reset button i get the menu to load normally or safe mode, it loads fine into both. This is the only way i can boot into windows, once into windows i can restart from start menu and it restarts fine, its only when first turning the system on this occurs.
    On top of that the system randomly locks up when surfing the net/messenger/winamp. Yet can do an Everest stability test for 30min perfectly fine, can do an Nvidia stabilty test for 30min perfectly fine, ran bioshock for 3 hours all settings maxed out perfectly fine. It seems to be a windows related issue.
    Any idea except a system format?
    System specs:
    Amd skt939 X2 4800+
    MSI K8N Neo4 Platinum
    2x1Gb G.Skill 3200+ DDR
    Nvidia 8800GTX
    200Gb SATA Seagate
    Yeah i know the 3d card is a bit OTT compared to the rest of the system, bought it now to play Bioshock, quake wars and crysis, was planning a full upgrade next spring anyway.
    P.S. It locked up just as i finished typing this, thank got for Firefox session restore ^^
    Update:- Done BIOS update and still didnt help. Done a BIOS reset and redone all the settings ensuring all clock speeds and voltages were correct. Also when i upgraded i removed my floppy drive, removed all mention of it as well including in hardware Boot sequence. Seems to be working now. Very strange considering all settings were correct before hand :grr:
  2. DougEdey
    5 Jul 2005
    Check your BIOS is updated for that motherboard.
  3. mk-donald
    mk-donald bits and bobs
    2 Aug 2007
    Just clutching at straws to help:
    Did you do a complete driver clean to get rid of all residue of ATI drivers
    and going back to basic (super) VGA in Windows
    before installing the nVidia drivers ?
    If not then maybe best to clean now (maybe for both the ATI and nVidia)
    and have another go at loading the latest nVidia (eg using their online video card detector) rather than anything that came with the card.
    I believe the freeware Driver Cleaner Pro is THE tool most generally recommended
    eg http://downloads.guru3d.com/download.php?det=745
  4. kenco_uk
    28 Nov 2003
    ^ what mk-donald said ^
    When switching from one flavour (ATI) of gfx card to another (NVidia) you NEED to uninstall the previous gfx drivers with the old gfx card still in. It's also a good idea to dl driverclean and follow the instructions to the letter. This will then give you a clean slate to install your new video card.
  5. Caracortada_uk
    29 Dec 2004
    Done 3 times now even from within safe mode and freshly downloaded drivers incase it was a fault there, error continues. About to update bios will update.
  6. Caracortada_uk
    29 Dec 2004
    Updated. See original post.
  7. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    what's your PSU? how are the voltages? the 8800GTX draws a lot more power than the x800 even at idle and it may be pushing your PSU over the edge
  8. Caracortada_uk
    29 Dec 2004
    580W Hiper PSU. In the case is 1 SATA HD, 1 DVD ROM, 1 DVD RW. All same cable, all other used for MoBo and GTX.
    Voltages:
    CPU 1.3V = 1.31V
    +3.3V = 3.36V
    +5V = 5.08V
    +12V = 12.04V
    +5V standby = 5.14V
