Windows System Restore problem
Discussion in 'Software' started by REDDEVIL-UK1, 14 Dec 2014.
  1. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    Hi, i have a problem that is really bugging me here :wallbash: and i can find no fix for so i'm hoping someone can help...:thumb:
    http://tinypic.com/m/igyxds/1
    The above link is a screenshot of what i'd like my system restore settings to be like
    but
    http://tinypic.com/m/igyxeg/1
    The next link is a screenshot of what keeps happening, and that is it keeps turning itself on and setting how much space to use at 50%
    So is there any way of completely disabling system restore or at least getting it to stay at the setting shown in the first link.
    Thanks in advance :thumb::D
    Btw i'm using windows 7 Ultimate x64
  2. GoodBytes
    20 Jan 2007
    Its supposed to be disabled, when you disable it and restart the system
    I don't know why it reverts. You have something that turns it back on and set it to 50% for you.
    To disable it completly, if I recall correctly, you can just stop and disable Volume Shadow Copy service.
  3. REDDEVIL-UK1
    REDDEVIL-UK1 MUFC
    17 Feb 2010
    That fixed the problem, thank you! :thumb::D
