Windows System Tray Disappeared
Discussion in 'Software' started by TekMonkey, 28 Feb 2004.
  1. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Somehow or another my system tray got disabled. The icons aren't just hidden. When I go to Taskbar and Start Menu Properties, "Hide inactive icons" is greyed out. Did I maybe disable a service or something?
  2. tk421
    tk421 Idiot.
    15 Jan 2002
    did you try a reboot?
    (sorry if it sounds stupid, but i gottta ask)
    not running a dock program or object bar maybe? something that would alter the windows taskbar/systray?
  3. TekMonkey
    6 Dec 2002
    Yes, I did reboot.
    I am running Y'z Dock. This has never happened to me before. Recently, I screwed something up and had to reinstall Windows. After I first installed it, it worked fine, but I noticed later after I had downloaded some stuff it dissapeared. I know that I should try uninstalling the apps and see if that fixes it, but I was just checking to make sure there wasn't a setting or something, first.
  4. tk421
    tk421 Idiot.
    15 Jan 2002
    i use object dock, not y'z .. but OD has a "disable windows taskbar" checkbox in the settings somewhere ... could be it.
  5. TekMonkey
    6 Dec 2002
    I can't find anything like that in the options. Plus when I close the dock, systray is still gone.
    I remember a process called systray.exe, or is that not in XP? I don't have that process running...is there some way that I turned it off?
