Tagan PipeRock II series (Available NOW)
Discussion in 'Tagan / Seasonic / SilverPower' started by Nathan@Nanopoint, 14 May 2009.
  1. Nathan@Nanopoint
    Nathan@Nanopoint Ctrl Alt Del
    2 Feb 2009
    This week the UK see's the launch of the Tagan PipeRock II (BZII) series
    [​IMG] [​IMG] [​IMG]
    TG680-BZII 84.99 ex vat
    TG780-BZII 99.99 ex vat
    TG880-BZII 109.99 ex vat
    PipeRock II combines a modular cable management with high-quality interior of the award-winning SuperRock series. Exceptionally high efficiency levels up to 88% and an especially high performance and stability on the +12 V rail, reached through the use of DC-DC technology, will make the power supplies to energy-saving and efficient partners of gamers and ambitious home and office users. High-quality components such as Japanese brand capacitors, hydro-dynamically supported very silent 120 mm fans and protection circuits ensure a permanently reliable operation. The blue illuminated Tagan logo delivers a spacey ambience.
    Key features
    • Modular Cable Management
    • Efficiency >82% and enhanced power distribution due to DC-DC technology
    • Very silent due to hydro-dynamically supported 120 mm fan
    • Impressive blue Logo lighting
    • Powerful
    • Reliable due to high-value components
    Full list of features• Compliant with higher versions of Intel EPS12V Ver.2.91 and standard ATX Ver.2.2.
    • Four independent +12V rails provide different devices individual power thus making the system stable
    • Universal motherboard compatibility due to 20+4 pin main power as well as 4-pin & 8-pin +12V power connectors
    • High efficiency > 82 % means: power supply produces less heat and emits less noise, an economical and ecological solution
    • 6+2 pin & 6 pin PCI Express connectors support NVIDIA SLI and Quad-SLI technologies and ATI Crossfire graphic cards
    • Total 11 IDE and SATA hard disk connectors available for top usage
    • Thermal fan control automatically adjusts fan speed thus controlling the temperature inside the power supply (Fan speeds up when temperature rises)
    • Internal OVP (Over Voltage Protection) and OCP (Over Current Protection) functions help to eliminate sudden power surge which cause damages to peripherals
    • Universal AC input range for all countries: 100~240 VAC with active PFC for better electricity performance
    • Embedded AC input socket avoids interference with PC case
    • High durability due to Japanese brand capacitor allowing reliable high temperatures
  2. Lee@Nanopoint
    Lee@Nanopoint Computer says yes!
    27 Feb 2009
