Case Mod - In Progress -Tainted Freshly Squeezed- COMPLETE + PICTURES
Discussion in 'Project Logs' started by barfastic, 27 Dec 2011.
  1. 330td
    330td Minimodder
    12 Aug 2004
    Is that a permanent marker you used?
  2. barfastic
    barfastic What's a Dremel?
    21 Feb 2011
    not really, its a paint tip marker... the actual pen ahs paint in it... sort of like a POSCA marker by UNI...
  3. xtoxm
    xtoxm What's a Dremel?
    6 Feb 2012
    Looks fantastic! Really loving the orange, its a colour im thinking of using in a mod for the near future. really like the LD case to, its HUGE! any more updates?
  4. barfastic
    21 Feb 2011
    Update time :D
    I put together a test system to check for leaks... But ill get to that soon! :)
    Fans spinning :)
    i was a little bummed out when i found out i cant have push pull on my top rad, i got 60mm of rad and 25 per fan... Total of 110, and i think the clearance is 95mm :( no worries though, installed the fans and the rad...
    I also received some new lamptron buttons, they arent the usual round ones, instead they are sort of like crosses and triangles, a clearer picture when done will help you understand!
    Sat and figured out the best tubing route... Im not sure if its going to stay like this because i am having a problem locating a decent location for my reservoir...
    I must admit, i thought this case was big, but now that most things are in, im runnin out of space!
    Also, my test system consisted of a quad rad with fans, and a 360 witout fans, my cpu idled at 30c when it was 24degrees ambient. With an extra quad rad im guessing my temps are Going to be even better!! :) happy happy barf :)
    Furthermore, while looking at my case and thought there was a bit too much orange...
    So i changed it :p
    Coffee
    Hot air gun
    3M car vinyl (Black Matte)
    Cut to size
    Before
    After :D
    I was quite pleased with the result, even though its not perfect, that will change because i am going to re-apply it :D
    After iw as done, i looked at my mouse...
    and i thought that was too black... Time to change things :p
    Also had the chance to do some more vinyl work on my GPUS...
    Black matte PCI brackets :D
    And the crossfire Bridge ;)
    Thats it for now guys :D
    Until next time :D
    Sponsored by:
    Big shout out to Freddy from Highflow for the sponsorship![/CENTER]
  5. Reconnec7ed
    Reconnec7ed What's a Dremel?
    29 Feb 2012
    Beautiful job of the vinyl! :D
  6. barfastic
    21 Feb 2011
    Thanks alot!
    i finally figured out my tubing route...
    i need a few more 90's and 45's but its finally done!
    heres my idea... (thanks to Carl for his idea...) Using 90's and 45s i was able to route my fittings AROUND each other... making a cleaner route easier to acheive.
    It goes GPU -> Left ram (bottom) -> CPU in -> Right Ram(Bottom) -> Rad -> Mosfet
  7. barfastic
    21 Feb 2011
    I Had some free time and finished up some mini mods on my psu... Here is what i did.
    Before:*
    After:*
    Before:
    After:
    I think the end result is nice and subtle enough without chaging the actual appearance too much:
    Sponsored by:
  8. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Or really voiding the warranty either :)
  9. barfastic
    21 Feb 2011
    Μιcro update!
    I sold my mouse to buy another one...
    Omg! I bought the same mouse! Lol...
    Its the newer version of the RAT, and it has a couple more buttons, but i really bought it for the orange highlights!
    I also installed the bottom rads...
    Thats it for now. Working on the secret part now...
  10. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    When I do paint fills like that I use the paint that you'd use for scale models, and then wipe it off with paint thinner. It won't hurt delrin at all, but a metallic might pop more there (as it's got the sparkles to catch the light.)
  11. barfastic
    21 Feb 2011
    Ill keep that in mind for next time Kayin! Thanks for the tip!!
    So today i got a small envelope from the USA
    Very strange and hard envelope!
    but inside i found a little suprise :D
    Made a quick cup of Joe, and got to work :D
    X-fire bridge = Perfectly the way i wanted it!
    Next was the stickers amde for the GPU backplates
    and an Overall shot of the GPU +Bridge, and ribbon!
    Next up my HDDS
    The reason for labelling was in case of Failure of one of the disks in the RAID, locating it will be easier than having to search through sata cables!
    And lastly the Memory sticks....
    Because of the complicated design of the stickers it was seperaed into 3 different stickers!
    The first sticker was to cover a weird bump/scrape all my dimms have on both sides, while at the same time allowing for the glossy stickers that will go above it to POP :D
    Second part is the usual Dominator three line logo, with a new font to match the build in gloss orange
    And the last part was the white glossy letters!
    And this is the final outcome!
    I ahve atleast another 30sets so i can re-seat any that may come out wrong.
    Right now i want to say a HUUUUUUGE thank you to Mr. Ben Lavinge, for helping me desing, customize and actually cut these stickers and ship them to me all the way over from the USA to Greece! Without him these stickers would of never been possible!
    Unfortunately these photos will ahve to do for now, as i am without my DSLR. (Finally after 2 months of waiting my upgrade is coming on saturday!)
    Hope you enjoyed this update!
    More to come over the next couple of days!
  12. Mizugetsu
    Mizugetsu What's a Dremel?
    12 Aug 2008
    The memory looks terrific actually the whole thing is looking superb
  13. xtoxm
    6 Feb 2012
    Where abouts did you order your stickers from? Keep up the good work i love the attention to detail!
  14. barfastic
    21 Feb 2011
    Thank you!
    A member from another forum. If you want PM me, and ill send you his contact details!
  15. bluc
    bluc What's a Dremel?
    4 Apr 2012
    That vinyl looks interesting does it have an adhesive that is activated by heat or does it kind of melt onto the surface? is it hard to remove?
  16. Marcusk
    Marcusk What's a Dremel?
    31 Mar 2012
    The 3M vinyls have a normal "tape" style glue on them, and can be put on even without heating them. You heat it up to make it softer and easier to apply to non flat surfaces. It works great even without a heatgun, a normal hairblower gives more then enough heat to apply it.
    It doesn't seem to leave any residue either, and is very easy to remove if you heat it up again.
  17. barfastic
    21 Feb 2011
    Bluc, Marcusk explained it in full detail!
    Think of it as a large Sticker, but more durable than paper. Application is REALLY easy, and removal is as easy... it doesnt leave any residue, and it can be re-used. (even if you crush it up, using heat it regains its original form!
  18. DennE_II
    DennE_II What's a Dremel?
    20 Jun 2012
    The mods look great and i can't wait to see more...
    Must ask you though, I just moved to Greece and have no idea where to look for PC components.
    and suggestions?
    Keep up the good work. :rock:
  19. Furball Zen
    25 Jan 2012
    It doesnt leave residue, and heat is not required for removal either. :D
  20. Mcbeer
    Mcbeer What's a Dremel?
    30 Apr 2012
    You good sir have the exact same idea i had about this case so far. The case, the fans, the theme. I am so sad nao :( - And great job in that PSU fan cover, looks very sleek.
    Great mod so far, give moar!
