Modding Taking paint off aluminium
Discussion in 'Modding' started by Mighty Yoshimi, 28 Dec 2006.
  1. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    What methods can be used to remove paint from aluminium on a large scale.
  2. ComputerKing
    8 Sep 2006
    man , Personally , On my big ass case , With white paint , I will sand it to death to make it silver ( alum... )
    use the sanding machine or by hand sanding !!!
    Good luck
    Computerking
  3. ỒĊBłůē
    ỒĊBłůē Also available in black
    2 Mar 2005
    Pay to have it sandblasted perhaps?
  4. Mighty Yoshimi
    4 Sep 2006
    I could do, i was thinking of trying a fine grained Belt sander, will this work?
  5. ỒĊBłůē
    2 Mar 2005
    What kind of area are we looking at here?
  6. Washfordmonkey
    Washfordmonkey What's a Dremel?
    6 Dec 2005
    might bring this up.. id be doing it on my mr2.. underneith the black paint is lovely aluminium!!
  7. led_zeppelinzoso
    led_zeppelinzoso What's a Dremel?
    13 Jul 2006
    if you want to go down to bare alum, get some Terpinsol, or paint thinner. but dont use it on plastic, it will melt through it.
  8. NysoO
    NysoO Handcrafted
    2 Nov 2006
    The easiest way is to use a machine with like 120 grit to take away most of the paint. But you end with some wetsanding to get that neat look.
  9. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    what ever you do dont use a belt sander. it eats away material like fire. you will get uneven dips and whatnot.
  10. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    For stripping a car down, use a sandblaster, or walnut shell blaster... The ladder won't hurt the metal (and therefore is good to use on cars with a lot of rust).
  11. Emon
    Emon What's a Dremel?
    14 Jun 2004
    A chemical paint stripper is by far the fastest and easiest solution.
    Just make sure it's actually paint and not an anodized finish, as is typically done on aluminum. An easy test would be to take some acetone (nail polish remover) and see if you can rub a little bit of it off in a small spot. Don't worry, acetone isn't nearly aggressive enough to remove the paint, but it will take a little off.
  12. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    an mr2 (a car) would not be anodized. i say either get a palm sander, not a belt sander, but one that just vibrates, or pay to have it shot with walnut shells. the shells work like sandblasting, but not as aggressive. since the metal is harder than the shells, they distort rather than the body. the paint, however, isnt and will come off very easily.
    are you going to polish the body of your mr2? that would be completely badass, but a very long process. be careful about blinding other drivers, though. bear in mind that not all of it will be aluminum. one of my friends has a 2nd gen and the bumpers and side skirts are composite, either FRP or fiberglass. those and other body panels will need to be painted.
  13. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    brake fluid is an excellent paint stripper..
  14. Cerenkov
    Cerenkov What's a Dremel?
    13 Dec 2004
    To strip anodized aluminum, use a very low grit sand paper on a sanding block and do it by hand. 150 or 300 (or do both). Use a sanding block to prevent dips made by the shape of your hand. Doing it chemically would most likely be suckage.
  15. Gramps
    Gramps What's a Dremel?
    15 Oct 2006
  16. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    "aircraft stripper" good stuff to spray on and wipe off the paint
  17. Nitro-Max
    Nitro-Max What's a Dremel?
    11 Feb 2007
    yes it is lol i learned that years ago when somone started doing my head in :)
  18. hujambo_Bwana
    hujambo_Bwana What's a Dremel?
    2 Aug 2006
    Or use a flap wheel in a drill...
  19. Rage.
    Rage. What's a Dremel?
    3 Mar 2007
    You can use oven cleaner to strip paint off aluminium.. its usually anodised ( the process of running a current through it to make the paint stick ) so oven cleaner will do great. just make sure u dont touch it because it WILL burn your hands. Otherwise just use a sander of some sort.
  20. El1m1nate
    El1m1nate What's a Dremel?
    6 Mar 2007
    maybe try methelated spirits?
