can someone list the tap sizes and drill bit sizes needed for a custom case, i.e. for the motherboard, drive cage, etc. Thanks
I used 6-32 for my entire case, had to tap the HD,CD,& DVD mounting holes to accommodate, but otherwise everything else worked out fine. When I bought the tap it came with the correct sized drill bit. I'm afraid I don't know what the equivalent mm sized bolt would be . Hope this helps.
