Cooling Tec Help PELT
Discussion in 'Hardware' started by Pie_uk, 25 Sep 2005.
  1. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    ok i have gained a pelt from ripping apart a mini fridge, i undersatand about putting it into a molex and tapping the red wire onto the yellow wire from a molex , but will this TEC be able to handle it? i wont be using it for cooling a cpu i just want to see if it will work , here are some pics
    [img=http://img244.imageshack.us/img244/4155/petespicsdigicam1620ao.jpg]
    ps there is no thermal compound on the tec it has got a heat sink tho , i was thinking of using a thermal pad?
    what do you guys reckon, obv i'll have to use a different psu which i have spare 400w, ill link up the 2 correct pins to trick the PSU
    what you reckon?
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Nope.
    Those won't handle a CPU or anything, they aren't rated high enough. :)
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    You can connect it up as you mentioned. Should be 12v, from a quick google. Found a site listing similar model numbers to that, and following that chart it *might* be a 172w tec, running between 12 and 24v.
    Run it on a dedi PSU, and make sure you cool the hot side.
    Actually, looking at the size of that sink, would suggest ~60w max maybe even less....
  4. Pie_uk
    6 Apr 2005
    ah wow thanks for quick informative replys i googled that number and found that its a 37w TEC http://www.web-tronics.com/37wapemot.html also one of ther corners is cracked etc is it safe to test it? thanks [​IMG]
    ok so i no how to get the psu on, link up 13 and 14 or something, ok what compound can i use for the TEC, i have some artic silver epoxy, so it will stick on there forever, im gussing the hot side id the side without the writing
    and whats a dedi psu?
  5. Shadowed_fury
    21 Nov 2003
    Dedi PSU - Dedicated PSU :)
    Arctic silver is fine.
    And, 37w... is that even enough for a NB? :p
  6. Pie_uk
    6 Apr 2005
    lol prob not just tried turning on psu without it being connected to pc and it didnt work
  7. Pie_uk
    6 Apr 2005
    ok i did this [​IMG]
    turned the PSU on for a sec but didnt hear any fans start? have i blown it?
  8. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Some psus dont like being on with no load and they immediately shut back off, but it should be ok. That is green wire to black wire, right?
  9. Highland3r
    25 Jul 2003
    Attatch an optical drive or summit to give a little load.
  10. Pie_uk
    6 Apr 2005
    as in cd rw or something? thanks for the info !!! i thought my psu was dead
  11. Highland3r
    25 Jul 2003
    Yea, doesnt matter what it is, as long as it loads 12 and 5v. A high power fan might do the job too, or possibly an old hard drive
  12. Pie_uk
    6 Apr 2005
    ah well an old hard drive i can do cheers ill let you know whats happining :D
