Windows Tech support Scam
Discussion in 'Software' started by Clesm, 31 Mar 2011.
  1. Clesm
    Clesm What's a Dremel?
    5 Feb 2007
    Was wondering if someone can give me some pointers before i do a long drive to devon.
    A friend of the inlaws (shes 75) fell for one of these telephone you need your computer fixing scams from what i can tell from my father inlaw they have taken off avg, put on Rising cloud and ccleaner given her a 9year telephone deal and taken over £100 from her.
    Has anyone had to mop up one of these already and if so anything i should look for in particular?
    Cheers
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Paid by credit card? Call the bank, get the charge reversed.
  3. dancingbear84
    dancingbear84 error 404
    16 Oct 2010
    I live in Devon, roughly what part do they live, I could take a look if you like, save you a huge ass trip. Otherwise you could try log me in or team viewer for remote access to them. I happen to know that Piriform Ccleaner is legit, It is a registry cleaner we use at work.
    Rising cloud appears to be of Chinese. I would try to reinstall.
    We find at work that a USB key with the latest Super anti spyware portable version installed and the install .exe of Malware Bytes Anti Malware cleans most things we throw at it.
    Procedure:
    1. Safe Mode
    2 Run SAS from the USB key and update
    3 run a full/complete scan
    3b Make a brew
    4 clean up
    5 DO NOT REBOOT WHEN PROMPTED
    6 Install MBAM
    7 Update
    8 Run full scan
    8b Make another brew
    9 Clean up
    10 Reboot into normal mode
    11 Turn off system restore
    12 Run SAS from USB key and update and run full scan
    13 This should come up clear
    14 Run MBAM again and have another brew
    15 If both come up clear, run Piriform Ccleaner and do a registry clean (Make a backup first)
    16 Clean all temp files etc
    Sorry if I telling you stuff you already know, just trying to be helpful
  4. Clesm
    5 Feb 2007
    Yep and cancelled incase they try to use it at a later date....
  5. Clesm
    5 Feb 2007
    Cheers for the offer but she wouldn't be happy with someone she didn't know apprently very sheepish about what she did anyway she thought it was someone from her isp...
    yep i've used ccleaner before as well, tbh looks like they haven't done anything mailcious just taken her and her credit card fro a bit of a ride...
