temp bad
Discussion in 'Hardware' started by darkhunter, 1 Aug 2004.
  1. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    ok at what temp does it become bad for my processor to be running at
    and when i shut down or restart the first time it trys to start my screen stays off then i turn it off and thurn it on again and it works. Why? and hhow can i fix
  2. El_JimBob
    El_JimBob Minimodder
    28 Dec 2003
    Hey, if yr computer's running fine and all is well, there's no real need to worry about the temperature of certain components.
    My overclocked Mobile Athlon 2500+ maxes out at around 60 degrees celcius sometimes, yet my computer is completely stable for hours and hours at a time. I wouldnt fret (unless of course you are having major heat-related problems). Your post was a little vague on a few points :)
    The issue with yr monitor may be something to do with it's 'power saving' mode. When I start or restart my computer, the monitor always switches itself off briefly before re-initialising itself.
    Does it not come on at all? Maybe you could give us a few pointers to try to help you along (ie: does the power LED on the monitor change colour when your computer is restarted?) This may help us get a better idea of yr problem.
    Good Luck :thumb:
  3. darkhunter
    13 Apr 2004
    ok i have a athlon 64 3200+ not overclocked and it runs in the 50-60 degree celisius range but it is very unstable sometime i wont make it past 15 miniets before i have to reboot and it says phsycal memory dump
    my moniter is fixed as long as i not overclocking it (good for now)
  4. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    If im not mistaken that is a little to warm for that chip. I dont even hit 60C when my heatsink is off. My system idles at 22C and under load its 32C.
  5. darkhunter
    13 Apr 2004
    yeah but is beeing that unstable ok for a athlon 64 3200
    i have athlon 64 fx 63 in my moms alienware downstairs and it has ever had a problem
  6. Froggy
    10 Jun 2003
    Im assuming you hand build this system with the A64. The Ailenware is designed to have a good airflow and cooling system for the processor. I Really think you should upgrade the cooling on the A64 because 60C is to hot IMHO for any chip.
  7. darkhunter
    13 Apr 2004
    ok but is that why it is so unstable and yes this is my second computer that ive hnadbuilt
