Watercooling Temp difference with coolant?
Discussion in 'Hardware' started by BU5H W00K1E, 22 Mar 2018.
  1. BU5H W00K1E
    BU5H W00K1E Minimodder
    18 Nov 2017
    So I just broke down my blocks and fully cleaned them after my Cryo-chillz disaster and i decided to run heaven bench for over an hour and noticed that my temps were down by a lot!
    Temps from Cryo chillz
    Cpu no load: 32c
    gpu no load: 29c
    Bench marked cpu: 57c
    bench marked gpu: 68c
    overlocked bench marked cpu:68c
    overclocked bench marked gpu:88c
    Now after cleaning the blocks after having to get a new pump due to the coolant clogging it here are the temps, also with distilled water only
    Cpu no load: 22c
    gpu no load: 17c
    Bench marked cpu: 43c
    bench marked gpu: 29c
    overlocked bench marked cpu:56c
    overclocked bench marked gpu:71c
    Is it possible that the coolant made that much of a difference? Or is it possible that i messed up installing the blocks the first time?
  2. Big Elf
    23 Apr 2009
    The coolant type (generally) won't make more than a degree or two difference. If you cleaned gunge from the blocks (CPU block mainly) it could have removed a lot of restriction which was causing higher temps.
    If you add around 50ml of ethylene glycol to a litre of distilled then it will help prevent corrosion, lubricate the pump and give some anti-bacterial protection. I always add a few drops of Benzalkonium chloride as well for anti-bacteria but it probably isn't needed.
    One of the most useful things you can add to the loop is a thermometer as it gives a quick indication of problems.
  3. BU5H W00K1E
    18 Nov 2017
    The build up in the pump is what was making the temps so high. and ill have to get some of that to add to the loop.
