I used to use ATItool to tell my temps, for some reason, none of the stuff is workign in the program, it juist shows up greyed? So, how do I fix this, or is there another program that also does this?
Iirc the 9800pro doesn't have temp probes built in only the 9800xt and X800pro / XT do, that's why unless your going to use a hardware probe you won't be able to monitor temps.
You need a R360core, on a XT board WITH temp sensor, and flashed to an XT bios. "you used to" as in, it worked before? The only other way afaik, is to view it through the ati control panel.
If you have the right Core and Board and the balls you can hardmod the board and unlock the temp controller. The guide is here http://www.techpowerup.com/articles/overclocking/vidcard/109
