Scratch Build – In Progress Temp name: Black Tower project [Update 16 Sep 2008]
Discussion in 'Project Logs' started by Anobis, 20 Apr 2008.
  1. The boy 4rm oz
    10 Apr 2008
    LOL Such a big box for only 5 items. When I ordered a sheet of MeshX they just duck taped it to the side of the box the rest of my stuff came in.
  2. Anobis
    Anobis What's a Dremel?
    28 Mar 2006
    Lol I had that 2 ones. But my meshx thy put between the kart board flaps on the bottom so you cud not seen it. I only noticed it wen i was cutting the box in pieces.
  3. Anobis
    28 Mar 2006
    A small update four now. Du to its way to hot. So I don't came much furder then building the upper switch panel with fill port.
    Hopefully its getting cooler in the evening :D
  4. cl0ck_ed
    cl0ck_ed I know what a Dremel is. Do you?
    28 Apr 2008
    That thing is Huge, lol, Great choice on the stacker amazing case. You'll have so much space to work in with the rads in the bottom compartment.
    :thumb:
  5. The boy 4rm oz
    10 Apr 2008
    Very nice switch panel mate.
  6. Anobis
    28 Mar 2006
    Lol it sure is :p I had 2 stacker's wasting space. so way not yous it :dremel:
    And the skeleton is very sturdy easy to modify :D
  7. Anobis
    28 Mar 2006
    Thanx m8 :D
  8. Anobis
    28 Mar 2006
    Ones a gain a small update four now.
    Made the lower switch panel. And this one was a pain in the rear end. The holes were overlapping in the back. So thy got a few bits broken. But thats not a biggy.
    Thay look out of line but thats not a problem. The holes are a bit bigger then the switch it self. Did dent had any drill bits that match the size good in nuf.
    So after painting it will be a lined better :dremel:
  9. Anobis
    28 Mar 2006
    Ok made a few pic's so every one can better visualize whats it gonna look like.
    Hire the upper switch panel. temp clamp 't on.
    And hire the lower switch panel. again temp clamp 't on.
    And in this last pic four now. I had made the front panel. Not finest yet.
    This is going be placed between the upper and lower switch panel :dremel:
    And that is it four now. Hope you like it so far :D
  10. The boy 4rm oz
    10 Apr 2008
    More switches. Looking good.
  11. Anobis
    28 Mar 2006
    Ok a nice update four now :D
    In this pic you can see the front panel i made.
    And in this pic i held up the main front panel. To have a look how its going look.
    In this pic i made the side blocks. Fits nice and tight :D
    And hire i made the lower front panel and side blocks.
    Hire i am holding the main front panel. To give me a good view and feeling :D
    But hire i noticed something not good. I had thought's if the switch wood fit properly. And yes thy don't fit good :wallbash:
    Ant i noticed it wood fit if i bent the connectors of the switch. Seen in pic below.
    And this is not what i wanted. It makes screwing the rings on the switches hard to :duh:
    So i probably gonna make a strip and place it under the switch panel. And adjust the length of the main front panel.
    So the switch is nice and free :dremel:
    But thats four a other time. The panels ain't glued ore what so ever. so i can change it if i wish :thumb:
  12. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    that looks very nice !!
    what will you use those switches for; light, fans ..?
    keep up the good work !
    ps. no neighbor cat today ? :lol:
  13. Anobis
    28 Mar 2006
    The switches are for lights 2x 2 10cm red neon four the air vents of the mobo unit. 1x 2 30cm red neon front. and 3x 2 10cm blue (maby changing to red) air vents.
    And the neighbor cat i ain't see her in a few day´s must be to hot. Its now mostly the entire day 30-31C degrees warm :eeek:
  14. compmodder
    compmodder What's a Dremel?
    23 Dec 2006
    wow, case is comin along quite nicely. i guess that 30* C is warm for u where u are; here in markham, ontario 30* is ideal temps (40-45 is what we call hot)
    can't wait for another update :thumb:
  15. The boy 4rm oz
    10 Apr 2008
    That font does look really nice. I never realized how versatile wood was.
  16. Anobis
    28 Mar 2006
    The highest i ever seen it rise over hire was 37C :eeek:
    I was once in Spain. And there it was 42C but that was a nice 42. The air was real dry. And don't feel like your skin is been hold just above boiling oil.
    Hire if you hold you arm in the sun. It feels like your arm is just a cm ore so above boiling oil. Du to the moist in the air.
    Normally the temp four may is between 18 and 22C.
  17. Anobis
    28 Mar 2006
    Me needer. I am learning this along i go :D
  18. Anobis
    28 Mar 2006
    Another update four now :D
    Du to the lower switch panel was to low i raised it by 30mm. seen on this pic been glued and clamp 't on.
    And I made an templit four the aluminum sheet that going be mounted on front.
    And hire shown on the main front panel.
    And sins a few day's my neighbor cat came bay. only four a short time. Until she went in a tree. To take a catnap. Forgot to take pic's it was so cute :D
  19. Anobis
    28 Mar 2006
    Totally forgotten this pic.
    I made this pic to let you see how its gonna look with the neon behind it :D
    So hire it is :D
  20. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    Wow! Incredible. So subscribed!! :thumb:
